VideoHelp.com Forum
Results 1 to 13 of 13
    What is a good DVD Player that has a USB port?
    Philips DVP5960 and USB thread. I use this one with a external Hard Drive.
    http://forum.videohelp.com/viewtopic...highlight=5960
    Does it play video from the external hard drive?
  4. Member ZippyP.'s Avatar
    Click the link and read.
  5. Yes it does & more......
    Thanks for your response. It really helped.
    I read that this unit has a USB1 port and requires FAT32 files. Is this correct? Is there any issue playing MPEG2 files from a hard drive at high data rates with a USB1 port? It seems in the early days of capture cards, this was an issue getting the data across at high data rates. Can the USB port power a 2.5 inch hard drive?
  8. Member Bodyslide's Avatar
    I have used a 2.5 inch USB2 drive. and it doesn't have enough power to run it. You will need to have an external power supply. I have an external 250gb usb2 3.5 case that I use with it....
    Can it play high bit rate MPEG2 files from a hard drive?
    It's 1.1 not 2.0 USB, high bitrate could be a problem we are talking a port the is something like 1 fortieth the speed of the 2.0 USB.
    The port is handiest for Divx/Xvid and pictures. It has played VOBs but high bitrate is not a value. IOWs 1 persons high bitrate is anothers mediaum and some elses low bitrate. It is subjective not objective.
    What is the best car and how come there are others being bought. same reason.
  11. All of those questions are covered in that link above.
  12. Originally Posted by drstew
    You will always need an external power to run your usb unit. The USB power supplied from the DVD player is not enough.
  13. The only bad thing about this unit it doesn't play all video formats, and that's the reason I return. I prefer to have a non usb dvd player who will play almost all video files from this planet.
  1. Replies: 8
    Last Post: 30th Nov 2010, 16:03
  2. dvd player with USB port (with NFTS support)?
    By themaster1 in forum DVD & Blu-ray Players
    Last Post: 10th Nov 2009, 19:33
  3. playing DVD images via USB port
    By cbrylla in forum DVD & Blu-ray Players
    Last Post: 12th Jan 2009, 13:08
  4. DVD Players with USB 2.0 port
    By nicoarad in forum DVD & Blu-ray Players
    Last Post: 28th Oct 2008, 21:06
  5. DVD player with USB port
    By Scooby Doo 12345 in forum DVD & Blu-ray Players
    Last Post: 14th Oct 2007, 08:35
