Is there a way to change .ass subs to .srt type? I dont know if there is a program that can do that.
Closed Thread
Results 1 to 18 of 18
Thread: ass subs converter?
Subtitle workshop says it can load them. If it can, then it should be able to give you .srt output.
Visualsubsync can convert between these format's without problem .
Simply open the .ass file with note pad and save as .srt.
Uncheck the unicode box (if it is in unicode)while saving if you want the new srt file to be compatable with most DVD author programs or to be edited in most subtitle programs.
I don't think so. They're very different layouts, though you could hack them by hand in an editor. The following though were created by reading into Subtitle Workshop and saving as another format.Originally Posted by Faithful Follower
ASS extract
SRTCode:[Script Info] ScriptType: v4.00+ Collisions: Normal PlayResX: 384 PlayResY: 288 Timer: 100.0000 [V4+ Styles] Format: Name, Fontname, Fontsize, PrimaryColour, SecondaryColour, OutlineColour, BackColour, Bold, Italic, Underline, StrikeOut, ScaleX, ScaleY, Spacing, Angle, BorderStyle, Outline, Shadow, Alignment, MarginL, MarginR, MarginV, Encoding Style: Default,Tahoma,24,&H00FFFFFF,&H00FFFFFF,&H00FFFFFF,&H00C0C0C0,-1,0,0,0,100,100,0,0.00,1,2,3,2,20,20,20,1 [Events] Format: Layer, Start, End, Style, Actor, MarginL, MarginR, MarginV, Effect, Text Dialogue: 0,0:00:32.20,0:00:33.10,Default,,0000,0000,0000,,Baldrick! Dialogue: 0,0:00:33.10,0:00:34.50,Default,,0000,0000,0000,,Yes, sir? Dialogue: 0,0:00:34.50,0:00:37.60,Default,,0000,0000,0000,,Get me some mulled ale, will you? I’m freezing.
PS: though this shows up here as some Unicode hash, in the files these are actually ANSI characters, I prefer to use real punctuation glyphs (curly quotes, long dashes, etc.)Code:1 00:00:32,200 --> 00:00:33,100 Baldrick! 2 00:00:33,100 --> 00:00:34,500 Yes, sir? 3 00:00:34,500 --> 00:00:37,600 Get me some mulled ale, will you? I’m freezing.
I've been doing this for the last 12 months or so. I won't give any advises if I hadn't test and/or tried it.
If the sub format is a text base subs, it will work.
Ofcourse, when saving, make sure save as ' All file '.
That is the same as ren *.ass *.srt. All it does is change the extension. As per above ass and srt are two quite different formats. Srt is basic, no formating, overlapping subs, effects, etc. Converting you will lose all formating and overlapping subs could be an issue.
If you look at the examples I posted above, you can see the differences. If your authoring apps can digest an ASS file renamed as SRT, it means they can read ASS format subs and probably you could just load the original ASS files. What apps did you do this with? Can you post an extract from your ASS file?Originally Posted by Faithful Follower
Subtitle Workshop is free and will do a real conversion.
Disregard Post.
Been away for a while and busy with work the last few months so I had no time for forums. My apologies for any emails I couldn't get to in time - missed you all! :-)
Well originally there was ssa (Sub Station Alpha). Then as I understand it it was expanded upon to add features people needed and eventually became Advanced Sub Station Alpha or ass. The next evolution would be Gabest's ssf which is even more feature rich.
celtic, you are correct that after saved as srt from ass, the overlapping subs will have to be fix, which can be easily done by any sub editors.
No matter which methods or programs you use, the special features of ass will be lost when converted to srt,. The OP asked exactly thisI first discovered this method when I used subresync to convert, when it is a text base sub, there's no need to OCR. I 'd compared the srt converted by subresync and the one with the method I mentioned, they are the same.Is there a way to change .ass subs to .srt type?
I would still like to see a sample of the ASS file you claim works by your method, and know which authoring app you are using.Originally Posted by Faithful Follower
If you are indeed loading your file into a subtitle editor first, that is probably converting it to a true SRT file.Originally Posted by Faithful Follower
they really should have picked a different file extension.
Actually .... Faithful Follower is correct, something which AlanHK would have seen if he hadn't been such a bore and a lazy one at that. You can just change the file extension from ass to srt, and most software vidplayers will just play whatever they can read in the file and skip the rest. WHY? BECAUSE THEY SEE IT AS AN *.ssa file of course, and those guys made it backward compatible, duh!?!
AlanHK should have tried stuff out before opening his big mouth and started dissing people.
What DA f is the importance of lay out or structure IF IT WORKS?!?! You can go all formal and say that they look different , in the end what matters is if it works or not.
Even my standalone hardware 40 bucks DVD player could see the ASS subfiles!!
And yes, Greymalkin of course they picked that extension on purpose .... are you 12?
you lazy A--, do it yourself why don't you?Originally Posted by AlanHKRiver Tam: ''Can't look, can't look!'' My old avatar: dress, movies
Aegisub is another freeware program that can export Advanced Substation Alpha subs (yes, PuzZLer, it is an .ass file) to .srt using "Export To..." under the File pulldown.
Reviving a three year old thread to make inane comments and personally abuse me.Originally Posted by KneeGrow
A jerk, an idiot and a troll all in one.
Jeez, I need to start looking at the dates on this! Here I was, thinking I was contributing, and its just a dead thread, resurrected for the sake of a petty feud. KneeGrow, you've got some issues.
KneeGrow, it's Ok to revive an old thread for certain updates, etc. with good judgement.
But this has got to be one of the lamest resurrections of a thread I have ever seen since I've been in forums.
I'm very serious - TRULY lame. And totally uncool. You need a life.Been away for a while and busy with work the last few months so I had no time for forums. My apologies for any emails I couldn't get to in time - missed you all! :-)
ASS subs Converter
By devilcoelhodog in forum SubtitleReplies: 0Last Post: 25th Jan 2012, 12:11 -
External subs don't play correctly with Anime .mkv with embedded subs (.ass
By Reveur in forum Software PlayingReplies: 1Last Post: 8th Nov 2011, 02:20 -
.ass subs
By Tylerr in forum EditingReplies: 7Last Post: 4th Jun 2011, 09:33 -
MKV with .ass or .ssa subs into mp4 for ipod
By lilly1991 in forum Newbie / General discussionsReplies: 0Last Post: 27th Jul 2010, 09:57 -
Problem with SSA/ASS hard subs
By Eva-Unit01 in forum SubtitleReplies: 0Last Post: 2nd Mar 2010, 11:17
