Is there a way I can check the quality of a burned audio CD? I know that the faster you burn, the more chance there are for errors. But is there a program that can actually show the difference between a disk burned at 16x, 32x and 40x?
If your drive supports CD-R quality scans like one of mine,LiteOn SOHR-5239S,then you can download Nero CD-DVD Speed and use it to scan for C1/C2 errors.This will give you an idea of the quality of the media your using and the optimal burn speed.
~Luke~
yeah I just found that program - how many c1, c2 errors are acceptable? I'm burning taiyo yuden 52x discs at 32x and I only had a couple of c1 errors and no c2 errors....I assume this is good?
With my LiteOn SOHR-5239S,anything under 800 C1 and no C2 is acceptable for my Taiyo Yuden and Mitsubishi Chemicals CD-R's.
Every drive will show a different amount of errors.
A couple of C1 errors is amazing.
Is your drive a reliable scanner?~Luke~
I don't know, it's just a cheap "Emprex" drive I bought at Fry's in 2004...
I've had drives that only show a few C1 and they are not reliable for CD-R quality scans.
At CDFreaks they use the LiteOn SOHR-5239S for some tests in their drive reviews section,so I bought one and put it into an external case and connected via firewire.For example look here.
They use K-Probe but I use CD-DVD Speed instead.~Luke~
I see... What's the best cd/dvd burner out there? I read that a lot of people liked Pioneer
The Pioneer 111 is very good for DVD and CD burning.
I like my LG GSA-4167B as it gives good burns on TY and Mitsubishi Chemicals CD-R's.It likes DVD media with the MID's TYG02 for -R and MCC003/4 for +R.
So personally I'd recommend Pioneer 1st,LG 2nd,LiteOn or BenQ.
But for CD-R scanning I'd recommend the LiteOn SOHR-5239S,although the BenQ DW-1650/1655 can scan CD-R and DVD-/+R.
To get an idea for which writer is a good buy then look here,here and here~Luke~
best audio video quality of youtube poor quality and not hq flv videos.
By nusratjaveid in forum Video ConversionReplies: 3Last Post: 20th Jun 2010, 19:23 -
DVDs burn fine, but Audio CDs only burn 1st half of songs right...
By Xenogear900 in forum Authoring (VCD/SVCD)Replies: 7Last Post: 28th Jan 2010, 04:26 -
Getting a better quality burn
By brado09 in forum DVD RippingReplies: 6Last Post: 24th Apr 2009, 10:59 -
Philips 3576H burn quality tests and question about upconversion
By ministry88 in forum DVD & Blu-ray RecordersReplies: 17Last Post: 8th Jan 2009, 17:50 -
Quality reduction on Burn
By barkingcat in forum Authoring (DVD)Replies: 20Last Post: 24th Mar 2008, 07:58
