VideoHelp.com Forum
  1. I have just installed ffmpeg for the first time on my server machine which runs Slackware 10.2. The install goes fine and everything, and I have installed it with --enable-shared.
    The problem is that I can't get the output file with audio.
    I know that LAME is needed to encode mp3 tracks, and I have that installed. Also that is installed with --enable-shared.
    I installed ffmpeg with the following config:
    ./configure --enable-mp3lame --enable-shared --prefix=/usr
    ...and LAME with:
    ./configure --enable-shared --prefix=/usr
    And they both worked fine.
    I have tried alot of different command lines, like:
    ffmpeg -i source_file.avi dest_file.flv
    Gives me a correct flv file, but without the sound.
    ffmpeg -i source_file.avi -acodec mp3 dest_file.flv
    Returns an error saying "Unsupported codec for output stream #0.1". So my guess is that it's the mp3 lib that is messing with me.
    # ffmpeg -formats returns that I have mp3 support installed:
    File formats:
    // a bunch of codecs info (uninteresting stuff)
     DE mp3       MPEG audio layer 3
    // bla bla bla
     D A             mp3
     D A             mp3adu
    Anyone have any ideas, at all?
    I would disable decoding with lame and also enable nasm.
    --disable-decoder --enable-nasm
    Also check your ffmpeg config log.
    Assembly won't help, but it will encode faster if you get it working.
  3. Originally Posted by celtic_druid
    Okay thanks. Why would you want to disable decoder?
    Because apps tend to only link against lame for encoding and having decoding enabled can cause problems.
  1. Replies: 3
    Last Post: 7th Oct 2010, 15:23
  2. FFMPEG AVI to FLV Converting Help!
    By sp0oon in forum Video Conversion
    Last Post: 20th Jan 2010, 11:48
  3. FFMPEG and other avi to flv encoders...
    Last Post: 30th Oct 2009, 04:42
  4. Trouble converting AVI(divx)+MP3 to FLV+MP3
    By BLboy in forum Video Conversion
    Last Post: 21st Jul 2009, 04:36
  5. Mux a FLV AVI + MP3 -> FLV with ffmpeg or mencoder?
    By Colmino in forum Video Conversion
    Last Post: 29th Mar 2008, 22:11
