It might be helpful to have an option to "pad" the area around subtitles (lengthwise) when burning them to an image. Vertically speaking, its not a problem as you can just shift the position up and down to compensate for overscan.
I routinely use my iPod to export video to my TV, but often the beginning and ending of my subs get cut off due to the overscan. The only way I've been able to solve this is to shrink the image by 10% and use the letterbox feature under options to fill the space with black. This is an alright solution, but it reduces the quality (size) of the image. I would rather be able to specify an "off limits" area on the edges so when I burn my subs, they stay within titlesafe and don't get cutoff by my TV's overscan.
I know this is probably a pretty specific request, and their might not be much demand for it, but I thought I would suggest it anyhow.
Thanks for all the work you put into making such a fantastic program, Major.
Results 1 to 1 of 1
How to add ".ass" subtitles to a ..."h264" file?
By Tatsubon in forum SubtitleReplies: 3Last Post: 20th Apr 2012, 18:35 -
Restoring "Safe To Remove Hardware" Popup Confirmation
By CobraPilot in forum ComputerReplies: 8Last Post: 3rd Jan 2012, 12:35 -
Set "Output filename" As Default Global "File/segment title" In MkvMerge?
By LouieChuckyMerry in forum Video ConversionReplies: 0Last Post: 9th Jul 2011, 01:52 -
DVD larger than 4.7GB, is it safe to use "AutoFit" and burn on 4.
By geek2330 in forum SVCD2DVD & VOB2MPGReplies: 10Last Post: 10th Oct 2007, 14:49 -
is it safe to remove "analyze" files from DVD Shrink?
By Bamahusker in forum Newbie / General discussionsReplies: 2Last Post: 12th Jul 2007, 14:18
