I plan on running a yellow RCA cable from my PC in my office to watch AVI files but I have no idea how to import the audio. My PC does not have white and red RCA jacks for audio. Any ideas?
There should be an audio line out from your sound card. Composite video will be OK out to about 150ft assuming good coax, but high impedance audio won't go far without serious noise.
Easiest solution might be wireless. Something like this but cheaper. Consult Radio Shack.
http://www.compusa.com/products/prod...ct_code=335791Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about
Well I was trying to do it on the cheap, I actually bought a wireless solution for the video and audio. The video looked great, the audio was really soft and I had to turn the TV all the way up.
The really bad thing was that it ran at 2.4 GHz, my wifi and cordless phone also run at 2.4 GHz. I called the company and they said turn the wifi off and get a new phone. I said F u and am going to return it to Tiger Direct.
I use Microlink dLan plugs for the LAN have GB-PVR on XP/PC and connect to the LAN by ethernet cable to Hauppage Media-MVP and then S-video cable to the TV to access and play Video files off the PC. video and audio is good.
Use this to convert your sound card's mini pinplug to stereo RCA:
http://www.audiogear.com/cgi-bin/sho...&preadd=action
you can use one of these if your laptop has s-video http://www.svideo.com/prosvideo6.html
then the trick is the wireless part which results will vary on product but try this one its cheap enough to try it out http://sewelldirect.com/Wireless-Aud...o-Extender.asp
and if you dont have an s-video output http://sewelldirect.com/wireless-pc-to-tv.asp?&
all seem to run on 2.4 Ghz but here's a wired option tooo http://sewelldirect.com/pc-to-tv.asp
the soft audio might have been a low set slider in the soundcard mixer panel
A quality option is S/PDIF which can go 6m or more with either coax or optical but quality cables must be used. Coax has potential for for creating gound loops (ac hum) due to mismatched gounds. Optical cables can solve that for audio but the video coax might still create poblems over long lengths.
http://www.ramelectronics.net/html/d...io_cables.html
Sharing TV - 1 Vista Media Center Server to Vista Media Center PC
By JBredensteiner in forum Media Center PC / MediaCentersReplies: 8Last Post: 14th Jul 2007, 01:33 -
Media Center Help
By rwheeler in forum Video ConversionReplies: 4Last Post: 25th Jun 2007, 13:06 -
Not enough room on the dvd-r media
By ansberry in forum MacReplies: 10Last Post: 12th Jul 2005, 12:14 -
help with a media center
By tjbecht in forum Newbie / General discussionsReplies: 4Last Post: 26th May 2004, 18:06 -
Windows XP Media Center Edition /Media Center PC's
By bidiak in forum CapturingReplies: 1Last Post: 18th Jun 2003, 21:54
Newest guidesLatest tool updatesNew media commentsReplay Video Capture, if you can Watch it, you can Capture it ! and save it to your computer. More info or download trial! About   Advertise   Forum   Forum Archive   RSS Feeds   Statistics   Tools
