I am a newbie to all things tecno, so please spare me a few minutes of your time.
I have recently purchased an LG 42" plasma and hooked it up to a Panasonic DVD/VCR recorder - DMR-ES35v unit. The Plasma has an in-built HD tuner, but the unit is SD only.
I want to run a seperate STB, either SD or HD, but have been told that my DVD recorder can only record analogue signal. What does this mean. Is there a way I can hook up a STB to record the digital shows. Analogue signal is very poor in my area, so recording it will be a pain.
According to Panasonic web site, the specs listed for your DVD recorder model DMR-ES35VS do not contain any inputs for either a HDMI video source or a component (Y, PB, PR) video source. So I am assuming here that your STB have either an HDMI video output or a component (Y, PB, PR) output. If this is the case, then you are better off buying a better DVD recorder.
By the way, this is what Panasonic's specs state about your model DMR-ES35VS:- A/V Input[list:fcbeb2faee][list:fcbeb2faee][list:fcbeb2faee]S-Video Inputs: 2 (1 front)
Composite Video Inputs: 2 (1 front)
Audio L/R Inputs: 2 (1 front)
RF Inputs: 1 (VHF/UHF)
Panasonic DMR-ES35VS
I looked at the others high end Panasonic DVD recorders, say model DMR-EH55S for $500, and it does have the same problem as your model. The DMR-EH55S model has identical specs for A/V Inputs as listed above.
They may be a switch to convert, say component to S-video, but if I were you, I'd look somewhere else to find a recorder with the appropiate AV inputs. I was looking into buying a DVD recorder myself, and I was thinking about buying the DMR-EH55S, but now I realize that it is not worth the $500.
Most of the new technology will eventually be HDMI. So if I were to buy a DVD recorder, it has to have both HDMI/Component (Y.PB,RB) inputs.
Regards,
orestesdd
By the way, this is what another person on the net is saying about DVD recorders in general:
http://hometheater.about.com/od/dvdr...ecfaqintro.htm
and in particular related to your question:
http://hometheater.about.com/od/dvdr...vdrecgfaq3.htm
I hope this helps more. I guess you will not have a DVD recording accepting HDMI/components any time soon. This type of AV inputs will be the prefered type of AV inputs on a HD-DVD recorder (when it becomes available) or a Blu-ray recorder (again when it becomes available).
Regards,
orestesdd
Thanks for the info. Again, I wish I had of found this forum prior to my purchases. I guess you live by your mistakes.
Panasonic DMR-ES35V
By RobJenk in forum DVD & Blu-ray RecordersReplies: 0Last Post: 16th Dec 2010, 13:42 -
use Panasonic DMR-ES35V with universal remote?
By kar120c in forum DVD & Blu-ray RecordersReplies: 1Last Post: 29th Sep 2010, 14:14 -
Panasonic DVD Recorder-VCR Combo unit model "DMR-ES35V"
By Syd Jamal in forum DVD & Blu-ray RecordersReplies: 4Last Post: 17th Jan 2010, 15:27 -
Panasonic DMR ES35V DVD NoRead repair
By Lumpy2 in forum DVD & Blu-ray RecordersReplies: 28Last Post: 4th Jun 2009, 03:00 -
help for PANASONIC DMR-ES35V ......PLEASE!!!!
By samjc2007 in forum DVD & Blu-ray RecordersReplies: 2Last Post: 7th Jul 2007, 11:35
Statistics
Newest guides
Latest tool updates
New media comments
