Thanks to the AVISynth script I found on one of the ATSC to x264 tutorials, I have finally found the ideal solution.
Unfortunately I am unable to upload an example because my laptop is out of commission, but that problem will be fixed within the next week or so, and I will be uploading the final results with the new script.
As before, I realized that quite a bit of my speed issues were due to not having sufficient physical memory onboard. Unfortunately, that won't be resolved until I finish building the new system because I'm not sinking anymore money into the current setup. Once it's built, my current system will probably become a Linux video box, or most likely a plain Linux box, and 512MB should be more than enough.
But anyways, the results should be coming soon. Apart from using Lanczos4Resize2, there was no sharpening used. The end results are plenty sharp without it, and it was a slowdown I didn't need. Maybe I'll reenable it with the new system, but I doubt it, since the results look just fine on my TV.
Results 1 to 1 of 1
1080i hdtv transcoding issues
By topsyturvy in forum Video ConversionReplies: 9Last Post: 1st May 2011, 05:49 -
DVP5990 reverts back to 480P on my Mits 1080i TV
By dagmando in forum DVD & Blu-ray PlayersReplies: 1Last Post: 20th Feb 2009, 11:08 -
Issues converting ATSC HD (1080i) broadcast recording to H.264
By alex750 in forum Newbie / General discussionsReplies: 6Last Post: 14th May 2008, 09:03 -
HDTV: 1080i or 1088i, which is it ??? .. (SOLVED)
By vhelp in forum DVB / HDTVReplies: 12Last Post: 3rd Feb 2008, 21:53 -
Capture HD from your game consoles for around $300 (480p/720i/p/1080i/p)
By Mysteriouskk in forum CapturingReplies: 4Last Post: 22nd Oct 2007, 19:00
