VideoHelp.com Forum
  1. Can you burn playable dual-layer video DVDs in OS X without using Toast, just Disk Utility? This is just for straightforward burns where you already have ready-made AUDIO_TS and VIDEO_TS folders, have stored them in an uncompressed 8GB disk image which is properly named (all caps, no spaces), and where your burner auto-bitsets +R to -ROM. Is there anything missing that you still need a program like Toast for?
    Unless this has changed, my understanding is that Disk Utility cannot create a UDF format disc. You need to use DVD Imager to create that format before burning the resulting image file using Disk Utility. I don't know how DVD Imager works with dual-layer. http://lonestar.utsa.edu/llee/apples...dvdimager.html
    If you don't want Toast, you might consider buying Popcorn 2 for burning your DL discs.
  1. Replies: 7
    Last Post: 18th Nov 2011, 03:16
  2. Making a Dual Layer disk with menu
    By Regor21 in forum Authoring (DVD)
    Last Post: 8th Apr 2010, 08:34
  3. Break on dual layer disk
    By audax in forum Authoring (DVD)
    Last Post: 24th Jun 2009, 21:34
  4. Dual layer disc error (2nd layer not burning properly - AVCHD)
    By hhhgamewmx7 in forum Authoring (DVD)
    Last Post: 24th Aug 2008, 09:00
  5. Problems with Dual Layer disk burning.
    By qaa in forum Newbie / General discussions
    Last Post: 21st Apr 2008, 01:47
