Muxing stops with an error message saying that it would have to split the file but a parameter %1 is missing. I have not set the split option.
It happens with one specific video at approximately the same spot when MPEG Streamclip finds a single Timecode Break.
TOAST and Moviegate mux the video files just fine. However, I need two Audio Tracks on the authored DVD, so ffmpegX is the only application that offers the possibility to mux two audio tracks.
I was checking mplex options:
--ignore-seqend-markers|-M
Don't switch to a new output file if a sequence end marker
is encountered ithe input video.
Is the option used by ffmpegX? I identified the timecode break most likely to be a layer break. (MTR shows that in mode menu)
I think I give mplex a manual try (that will be an adventure)....
Results 1 to 1 of 1
Thread: Muxing error message
error message
By geerunner in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 27th Oct 2010, 20:58 -
VirtualDub Error Message - Video Compression Error
By HartsVideo in forum DVD RippingReplies: 19Last Post: 7th Jun 2009, 20:18 -
Winsubmux error. Plus submux not muxing
By Codecoder in forum Authoring (VCD/SVCD)Replies: 1Last Post: 12th Jul 2008, 22:30 -
Get many error messages, AviSynth error message and meGUI error
By MKVcrazy in forum Video ConversionReplies: 0Last Post: 25th Aug 2007, 16:41 -
Error message "CMOS checksum error - Default loaded"
By ChrisKS in forum ComputerReplies: 1Last Post: 27th Jun 2007, 01:16
