I have some VOB files where the default audio is French instead of English. I want to play them back (not convert them)in English.
WinDVD allows playing VOB, but has no language select. Maximus DVD has language select, but no VOB playback. Do any of the software players allow you to load VOBs and select language?
GuestYou can try the Windows Me original DVd player...write: dvdplay in your start-menu and then you get the player to play and you can select language.
You have to rename the folder where your .VOB files are to: VIDEO_TS!
Try it!
Is there a dvd player that you can select ycbcr601 other then the Xbox 360
By Evil Monkey in forum DVD & Blu-ray PlayersReplies: 1Last Post: 1st Jun 2009, 08:44 -
How do I name multiple srt files so that the language shows to select?
By JoeBolden in forum SubtitleReplies: 0Last Post: 29th Apr 2009, 13:02 -
Looking for software to select 10 min clip from DVD
By jimdagys in forum EditingReplies: 3Last Post: 17th Apr 2009, 08:20 -
Joining select VOB & IFO files?
By pmolson in forum Authoring (DVD)Replies: 2Last Post: 7th Nov 2008, 00:31 -
Which DV codec does capture software select?
By hollowman in forum CapturingReplies: 21Last Post: 24th Aug 2008, 13:53
Statistics
Newest guides
Latest tool updates
New media comments
