1080i is the shorthand name for a category of video modes. The number 1080 stands for 1080 lines of vertical resolution, while the letter i stands for interlaced or non-progressive scan. 1080i is considered to be an HDTV video mode. The term usually assumes a widescreen aspect ratio of 16:9, implying a horizontal resolution of 1920 pixels and a frame resolution of 1920 × 1080 or about 2.07 million pixels, and a field resolution of 1920 × 1080 / 2 (because it's interlaced) or about 1.04 million pixels. The field rate (not the frame rate) in hertz can be either implied by the context or specified after the letter i. The two field rates in common use are 50 and 60 Hz, with the former (1080i50) generally being used in traditional PAL and SECAM countries (Europe, Australia, much of Asia, Africa), the latter (1080i60) in traditional NTSC countries (e.g. United States, Canada and Japan). Both variants can be transported by both major digital television formats, ATSC and DVB.
http://en.wikipedia.org/wiki/1080i
Results 1 to 1 of 1
Thread: 1080i
Camcorder: buy 1080i or 1080p? Final Cut Express only does 1080i
By adrien23 in forum Camcorders (DV/HDV/AVCHD)Replies: 13Last Post: 12th Nov 2010, 05:37 -
720p vs 1080i - which is best?
By snadge in forum DVB / HDTVReplies: 19Last Post: 31st Aug 2009, 18:19 -
1080i vs. 1080p
By Shibblet in forum DVB / HDTVReplies: 31Last Post: 27th Sep 2008, 13:24 -
1080i to what ??
By David97 in forum Video ConversionReplies: 3Last Post: 4th Dec 2007, 07:55 -
Is 1080i thru Component the same video quality as 1080i thru HDMI?
By Denvers Dawgs in forum DVB / HDTVReplies: 27Last Post: 13th Jul 2007, 16:25
