VideoHelp.com Forum
    when I copy recorded programs from my Tivo unit to the Go-Video DVD Burner, I am able to play the burned DVD with no problems on the Go -Video DVD or any other stand alone DVD unit, but am unable to play or make additional copies on my PC, the dvd just hangs and I have to power off the pc and then open the drive. This has done it on every dvd I have tried to make additional copies of. Same problem going from VHS tape to DVD recordings.What am i doing wrong if anything? the Tivo unit is an older unit and is not capable of connecting to a pc directly. [/quote]
  2. Member Krispy Kritter's Avatar
    I expect the problem is with the format of the DVD's from the burner. Don't know why they would cause your pc to lock up, unless they are a type of disc not supported by the cdrom/dvdrom drive in your pc. Have you tried them in other pc's?
    Google is your Friend
  3. Member SingSing's Avatar
    Your problem is pretty common.
    You can try DVDshrink to capture the video to harddisk, then burn that version.
    You can also copy the the vob files to a harddisk folder, and use ifoedit to generate the ifo file, then burn it.
  1. Replies: 1
    Last Post: 2nd Jul 2009, 02:35
  2. DVD recorder that will record video direct from SDHC card
    By madtony in forum DVD & Blu-ray Recorders
    Last Post: 12th Apr 2009, 11:14
  3. What are the advantages of a dvd recorder over tivo?
    By zanos in forum DVD & Blu-ray Recorders
    Last Post: 29th Nov 2008, 12:44
  4. Copying some home video on VHS to DVD
    By syilim in forum Newbie / General discussions
    Last Post: 4th Nov 2008, 21:23
  5. dvd recorder/vhs copying question
    By nobbydadog in forum DVD & Blu-ray Recorders
    Last Post: 28th Dec 2007, 06:58
