VideoHelp.com Forum
  1. Member PTsniper's Avatar
    Thats it: how do I had the subtitles to a wmv video file.
    I've created my own subtitles with subtitle workshop (I'm not sure, but it doesn't matter), and the subs are in subtitle file, so my question is: how do I had this subtitles to a wmv movie. Is there any program that allows me to do that?
    Thanks.
    Do you want permanent subtitles in the video? then can you use virtualdub-mpeg2 with the vobsub subtitler filter and reconvert to wmv avi, http://forum.videohelp.com/viewtopic.php?t=272736 (use virtualdub-mpeg2 instead of virtualdubmod)
  3. Member PTsniper's Avatar
    Thanks so much man.
    I have only one question now: after I've add the subs the movie become a slower, is there any chance to improve that.
  4. Member PTsniper's Avatar
    Ups, forget this post.
    Now, one last thing: the video has 3,77 gb, and it's only a 8 minutes and 33 seconds movie, can I convert that to a smaller file?
    Thanks, thanks, thanks for everything
  5. I'm a MEGA Super Moderator Baldrick's Avatar
    Use a compression under Video->compression. You can for example use divx codec, xvid codec or wmv9 vcm codec.
  6. Member PTsniper's Avatar
    Alright,
    thanks a lot for everything.
  7. Member PTsniper's Avatar
    I convert that with Windows Media Player, and it works perfectly, than you so much for everything.
  1. Replies: 2
    Last Post: 23rd May 2011, 16:34
  2. Replies: 0
    Last Post: 27th Dec 2010, 15:53
  3. Having trouble adding subtitles to WMV HD
    By Modify_inc in forum Newbie / General discussions
    Last Post: 3rd Jan 2010, 00:30
  4. adding subtitles to xbox 360 compatible 5.1 wmv file
    By TF2MarkP in forum Newbie / General discussions
    Last Post: 30th Aug 2009, 19:16
  5. Replies: 2
    Last Post: 16th Oct 2007, 16:45
