i'm trying to backup a copy of my 'lock stock' movie but all the above mentioned programs failed... just tried anydvd and that seems to have failed too. shrink encountered 'data error - cyclic redundancy check', dvd2one gets stuck after it has copied around 1.88 Gb and says the files have to be copied onto the hard drive. dvdfab decrypter also gets stuck at around 1.88 gb. and anydvd just took so long i gave up...dvd decrypter just failed again at 1.88 Gb. i cannot understand why this is happening cause the dvd works perfectly fine... any suggestions would really help..
thanks
deSaad
try RipIt4Me
Do a search for 'cyclic redundancy check' it's come up on here 100's of times.
He's a liar and a murderer, and I say that with all due respect.
Your dvd reader sees and chokes on the scartches that your dvd player can handled.
@ steveryan
i did, i went through most of the posts i could find, thats why i tried anydvd and dvd fab decrypter...
@singsing
the dvd is almost devoid of any scratches
almost being the operative word. If RipIt4Me fails to beat it, then scratches would be the next most likely culprit. All it takes is a scratch in the wrong place.
If the disc is scratched, you'll need to clean it. Sometimes, even that won't work.
I've had luck using a different drive to read with: In particular, I have an ancient (now - 4 years old) Panasonic that reads well; better than any other. I keep it in an external enclosure just for tough discs.;/ l ,[____], Its a Jeep thing,
l---L---o||||||o- you wouldn't understand.
(.)_) (.)_)-----)_) "Only In A Jeep"
DVD Fab - DVD Shrink - DVD Decrypter OK, and disc is unusable?
By dledm in forum DVD RippingReplies: 7Last Post: 1st Jun 2010, 14:54 -
question regarding DVD Fab Decrypter
By Bamahusker in forum DVD RippingReplies: 2Last Post: 3rd Mar 2010, 17:02 -
dvd fab HD Decrypter 6.2.0.5 help
By jyeh74 in forum Newbie / General discussionsReplies: 2Last Post: 11th Jan 2010, 03:55 -
CloneDvd2, Dvd Decrypter, Dvd Fab, Dvd Shrink? Help Choosing Software...
By frieday in forum DVD RippingReplies: 10Last Post: 5th Aug 2009, 08:14 -
DVD Fab HD Decrypter?
By wulf109 in forum Blu-ray RippingReplies: 20Last Post: 16th Sep 2008, 13:41
