Hey there,
I have some problem with DVD-Lab pro.
I have a foreign dvd which does not contain dutch subtitles. I want to make this dvd with dutch subtitles.
So I demux the vob files with Pcgdemux.
Then I look for the appropiate dvd-subtitle and with Dvd-Lab pro I compile the dvd.
Although the compiling is not that rather difficult I don't really understand how it works with the subtitles. It appears there are subtitles with 30 fps, 29,97 fps or 25 fps and in PAL or NTSC.![]()
I can add them to the project in dvd-lab pro, but it would be helpfull if I could preview the subtitles in combination with the video-stream. (m2v). In Dvd-lab pro I only can see a preview, but without the subtitles.
Since the compling is taking some time (about 20-25 minutes) I cannot find a way to see whether the undertitle is in sync with the audio.
Does anyone know how I can see their in sync in Dvd-lab Pro?
And how can I see for which format the subtitle is made, e.g. PAL or NTSC and which framerate?
Many thanks,
Thread: Subtitle preview in DVD-Lab Pro
If you read the section in the manual for subtitles, it actually states that the subtitle editor is for basic adjustments to subtitles, and not a substitute for a full featured subtitle editor. I preview subtitle timing in Subtitle Workshop, and adjust if necessary. Subtitle Workshop can also tell you the framerate for your subs in most circumstances.
Why is'n there any programm, which it's makes possible to lay down the video file and subtitle file under each other, with the option to preview, and at the same time its showing how much fps each file is and if the film is in pal or ntsf. In this way one can visual sync subtitles and video together, without even bother to mess around with timeframes e.g.
Just as in Pinnacle Studio, here I can add effects, titles & transitions at the exact spot on the film I want it to be.
Such a program for easy syncing subs and video is just I need, all those other programs are to complicated and even if I try I always get stuck half the way because the setting in the manual differs from the real program.
Subtitle Workshop does this. Once you have everything where you need it, just load the results into your authoring tool.
DVD Lab Pro - Import .SSA subtitle problem
By satan999 in forum Authoring (DVD)Replies: 3Last Post: 27th Jan 2011, 07:21 -
DVD Lab Pro - New OS, same location of files = Subtitle generation = crash
By Paker in forum Authoring (DVD)Replies: 5Last Post: 18th Sep 2010, 08:56 -
DVD Preview - New Pro user
By Joolyan in forum SVCD2DVD & VOB2MPGReplies: 7Last Post: 29th Sep 2009, 14:12 -
Can i actualy preview the subs in the movie in DVD Lab ?
By mordor in forum SubtitleReplies: 0Last Post: 22nd Mar 2008, 09:02 -
DVD Lab Pro Subtitle Mapping issues
By ArtOfLosingMFZB in forum Authoring (DVD)Replies: 1Last Post: 2nd Feb 2008, 20:41
Statistics
Newest guides
Latest tool updates
New media comments
