VideoHelp.com Forum
Results 1 to 10 of 10
  1. Member SerbianBoss's Avatar
    I work with DV avi(interlaced,Pal) material and want to make xvid with virtual dub.
    Does is this good filter order:
    Use deinterlance filter(asvzzz deinterlance)
    Use internal VD resize filter
    Use some denoise filter
    Use sharpening filter
    Use some color correction filter
    What you thing about this filter order in virtual dub.Is that ok or is better to change something.
  2. Member DVWannaB's Avatar
    my suggestion is:
  3. Member SerbianBoss's Avatar
    thanks, any more comment?
  4. Член BJ_M's Avatar
    it would be a whole lot faster to do the resize just after deinterlace - then after , do everything else (as in the first post)..
    though to resize last will give better quality ...
  5. Member SerbianBoss's Avatar
    You think that better result will be if resize last?
  6. Член BJ_M's Avatar
    slightly
    Resizing last may have an impact on the time it takes in encoding tho.
    I'd try the sharpening filter last on that list, (IMHO) color correction after sharpening, may
    not be the best bet.
    The Devil`s always.....in the Details!
  8. Always Watching guns1inger's Avatar
    Sharpening must come after resizing, as the amount of sharpening will be heavily dependent on the results of resizing. I generally put it last unless there is a very good reason not to.
    Read my blogs here and here. Change England's Libel Laws - Sign Here
  9. Member SerbianBoss's Avatar
    So this is the winner combinatio or not?
  10. Member SerbianBoss's Avatar
    Does this settings can be used for filtering dvd(using avisynth).
    i mean does the order is ok for dvd(expect deinterlance because i want dvd to stay interlaced).
  1. Replies: 3
    Last Post: 10th Jun 2011, 11:16
  2. Virtual dub
    By santolina in forum Newbie / General discussions
    Last Post: 22nd Jul 2009, 13:48
  3. AC3 codec/filter with virtual dub and TMPGEnc
    By buzzsaw in forum Newbie / General discussions
    Last Post: 24th Apr 2009, 17:47
  4. help with virtual dub
    By Remyisme in forum Newbie / General discussions
    Last Post: 30th Jan 2008, 15:36
  5. Is there any filter (plugin) for Virtual Dub that will simulte DirectShow ?
    By donthenet in forum Newbie / General discussions
    Last Post: 14th Dec 2007, 07:44
