In Adobe Encore DVD 2: How can I copy stuff (menus, timelines, etc.) from one project to another?
Oh yeah, and secondly; is there no way to export your subtitles?
Thanks in advance !
As far as menus go....They're usually .PSD files that can be imported into any .ncor project..You don't need to copy them from project to project...
As far as timelines go, you're better off starting a new session, and importing them from your hard drive (wherever that may be).
You could also rename the .ncor project, and delete the assets you don't want...Of course, if you get an error message (which Encore used to be known for), then it's your own fault..
How to convert DVD project to Blu-Ray project??
By zentsang in forum Authoring (Blu-ray)Replies: 0Last Post: 9th Jul 2010, 17:08 -
Edit a HD project in Adobe Premiere pro 2?
By rajaa in forum EditingReplies: 12Last Post: 21st Apr 2009, 23:16 -
Help Neeeded For DVD Project. Extract DVD Menu For Use In Personal Project
By sephiros in forum Authoring (DVD)Replies: 2Last Post: 5th Nov 2008, 12:49 -
Adobe Premiere Pro 2.0 project file/autosave question
By wwervd316 in forum Newbie / General discussionsReplies: 0Last Post: 20th May 2008, 19:14 -
Adobe Premiere project using AVISynth AVS scripts crashes when rendering!
By Mark001 in forum EditingReplies: 2Last Post: 10th Jun 2007, 23:25
Statistics
Newest guides
Latest tool updates
New media comments
