Hello,
I have a movie file which uses (On2's) VP62 codec. Now I need some help after my QuickTime Player send me to the QuickTime Components page:
http://www.apple.com/quicktime/resou...omponents.html
I downloaded and extracted the file, but it does not look as decribed in the installation instructions (below): The extracted file is a folder (called "VP32 Folder") with lots of contents, but without the so called "on2vp3.component").
Can anyone tell me
-- if the whole folder is the component?
-- if the described location is really "/Library/QuickTime" or "/System/Library/QuickTime"?
Thanks in advance - here are the installation instructions:
1. Login as "root".
2. Extract the component from the file VP3QTOSX-3213-10182001.hqx (double click VP3QTOSX-3213-10182001.hqx OR open it with StuffIt Expander)
3. Move the extracted file (on2vp3.component) to the /Library/QuickTime folder on your Macintosh OS X startup disk.
a. I seriously doubt that VP3 will playback VP6 content.
b. When I try the link, I get VP3QTOSX-3220-20020211.sit, which is 4 months newer, but still quite old. My copy only contained 2 files, so maybe your extras are source code or something?
c. "/Library/QuickTime" is for 3rd party components; "/System/Library/QuickTime" is for Apple's own components.
d. Maybe you needed to log in as root in 2001-2002, but with 10.4, Admin rights are enough to put stuff in "/Library/QuickTime".
Installation/Uninstallation instructions
By Jirka Cech in forum ffmpegX general discussionReplies: 57Last Post: 24th Apr 2012, 16:45 -
Didn't quicktime pro come with mpeg-2 playback component?
By sirN in forum MacReplies: 10Last Post: 14th Nov 2009, 02:15 -
How to use the Quicktime MPEG-2 component
By tealgrey in forum MacReplies: 5Last Post: 10th Mar 2009, 16:30 -
Apple Quicktime Mpeg2 playback Component
By macuser1960 in forum ffmpegX general discussionReplies: 0Last Post: 2nd Mar 2009, 11:33 -
H.264 or On2 VP6
By Fking in forum Newbie / General discussionsReplies: 5Last Post: 6th Jun 2008, 10:13
Statistics
Newest guides
Latest tool updates
New media comments
