VideoHelp.com Forum
Results 1 to 10 of 10
    i have a ts file with resolution of 1080p and i would like to convert it to x264 using the MKV container. I would like to keep the original resolution of 1080p.
    I found a guide in the guide section but its a bit messy and it only converts the file and downgrades the resolution to 720p.
    where can i find some more guides on how to do that if its possible at all?
    The main reason i am doing this is to get the correct audio track playing as the main and only audio track.
    tested megui? i think you need to use dgindex for ts mpeg2( I assume it is mpeg2....hdtv can also be h264) input, see http://forum.doom9.org/showthread.php?t=112496
    i followed this guide http://nwgat.net/guides.htm
    the guide seems just fine but it downgrades it to 720p from 1080p.
    is there a possibility to keep to its original res to 1080p?
    thank you
    Remove the resizing in the avisynth script ( Lanczos4Resize ) .
    hehe that easy.
    thanks for the help Baldrick.
  6. Member edDV's Avatar
    A 1080p TS file is a rare find. I've been trying to find a sample.
    yea i got a couple of those, but mostly i got 1080i and 720p
    Watching 1080i and 1080p on your LCD monitor , you spot any diferences?
    Are all lcd progressive anyway?
    tnx
    Unless you have a really fast dual core or dual CPU system, you might want to skip X.264 encoding. I have a 3200+ AMD CPU which is supposed to be the equivalent of a 3.2 GHz Intel CPU and X.264 playbacks sucks big time on my system. I can't play anything back without it looking almost like slow motion, not even 720p encodes. X.264 is too cutting edge for me, but if your PC is fast enough to play it back or you just want to prepare for the future, I could understand that.
    I don't know about Europe, but in America no TS files are in 1080p format. If it's in 1080, it's 1080i. Only HD-DVD and maybe BluRay are in 1080p, but those aren't TS files. Maybe the original poster is wrong about his file being 1080p or maybe things are different in Europe.
    tnx
    not really. but from 720p to 1080i/p you do notice a difference. and yes LCDs are progressive.
    I do my encoding on a Xeon 3.0GHz and its quite slow. Slow encoding but acceptable to me as this is just one time. I am just doing it because the audio track is in japanase and i cant change the audio track with the HTPC software that i use to the english track. So i just encode the ts file to mkv with only the English Audio Track.
    In Europe not many channels have HDTV but SKY HD is 1080i. This one i got is from Japan thus the japanase default audio track. But i also have 2 other files with 1080p resolution that the default audio track is english. I dont belive the japanase have their default audio track on english so that two probably came from the US. Dont really know. I just know that they are huge and look awsome on my LCD panel.
    I do have other 720p x264 files and they play just fine on my HTPC system. At first i had lots of problems like the ones you mention but then i install some other x264 decoders and it all worked like a charm. At the moment i am using CoreAVC as my x264 decoder on my P4 3.2ghz and it runs just fine with 50% utilization if i am not mistaken.
  1. Shrinking 1080p MKV, change to 720p or keep as 1080p?
    By Phat J in forum Video Conversion
    Last Post: 28th Nov 2010, 09:35
  2. 720p or 1080p HDTV - Help
    By GerryR in forum DVB / HDTV
    Last Post: 21st Mar 2010, 20:08
  3. 1080P Playback On My PC? And WD 1080p Player Need A Expert!
    By wpittsen in forum Newbie / General discussions
    Last Post: 30th Sep 2009, 12:43
  4. 1080p hdtv rips?
    By jbaruch76 in forum Newbie / General discussions
    Last Post: 2nd Dec 2008, 01:12
