VideoHelp.com Forum
  1. I was just wondering when recording a laserdisk with a dvd recorder if I needed a new dvd for every side of the laserdisk or can I pause and then continue with the recording after I turn over the disk?
  2. Member canadateck's Avatar
    Yes Most |DVD Recorders can Pause. But it also depends on the length of the Film as well.
    I guess you don't have a LD player that plays both sides of the LaserDisc. Since the max. time per side on a CLV Laser is 60 min. (CAV is 30) you can easily record two-sided discs using the SP (2 Hour) mode. Record side one, pause, flip disc, record side two. Use the S-VHS output of the LD player if availlable.
  4. Member SingSing's Avatar
    Don't LD player has macrovision or similiar anti-copy scheme ?
  5. Laserdisc has no copy protection.
    Laserdisc side changes can be edited out and joined seamlessly by loading the DVD transfer recording into your computer, then trimming with a frame accurate MPEG2 editor like Womble MPEG-VCR or MPEG Video Wizard. The resulting MPG file can then be authored into a new finished DVD after that.
  6. Cool.
    Also. If I wanted to record the audio commentaries and such would I have to switch on the commentary on the laser and then record?
    I got tired of waiting for a SE DVD of a sertain movie so I bought the SE laserdisk so I can get the special features and put them on a DVD. The movie is out on DVD but I wanted the audio commentaries and other special features to put there with it.
  1. help recording my laptop with dvd recorder
    By xtube in forum Newbie / General discussions
    Last Post: 11th Aug 2010, 11:41
  2. dvd recorder can't do automatic programmed recording
    By dvdnewbie64 in forum DVD & Blu-ray Recorders
    Last Post: 5th Apr 2009, 16:40
  3. recording a mpg file right to dvd recorder
    By abrand88 in forum DVD & Blu-ray Recorders
    Last Post: 21st Feb 2009, 18:47
  4. Recording from one DVD recorder to another?
    By Trollheart in forum DVD & Blu-ray Recorders
    Last Post: 17th Mar 2008, 16:54
  5. Problem with recorder? Skipping only when recording on DVD
    By fastheart in forum Newbie / General discussions
    Last Post: 25th May 2007, 10:26
