VideoHelp.com Forum
  1. Member ambrosechapel's Avatar
    I have a number of files in MKV format and I can't play them.
    I have OS X 10.3.9 running on a G3 iBook, which is a bit underpowered for this kind of thing, but I normally get good results from VLC on most video files.
    VLC (0.8.5) won't open these files at all and neither will MPlayer for mac. VLC sometimes says "couldn't open" and sometimes says "no suitable access module".
    I guess it's possible there's actually something wrong with them?
    I installed the command line tools and when I do "mkvinfo <filename>" it says "No EBML head found".
    Should mkv files just work in VLC? I don't have to install anything else like the command-line tools or other libraries? Same with MPlayer?
    Having spent about a week torrenting these files, am I out of luck?
  2. I just solved this problem at least for me. Different files may well have different results. I used "ffmpegX " to convert to DivX play great now on my Mac using either Quicktime or VLC. Search this forum and you will find more info on how to do if you need it. or I could try to write out more on how I did it.
  3. Member ambrosechapel's Avatar
    Unfortunately ffmpegX can't read them either. I guess the files are corrupted in some way. I think I have to give up on these particular files. Other MKV files can be played OK. Oh wel...
  4. Member ambrosechapel's Avatar
    I'm posting to say ... oh my god I am such an idiot.
    But at least the story has a happy ending.
    I was trying to play files from an earlier, aborted attempt at torrenting the files, which were of course useless because they were only partially downloaded. Now that I've found the actual files, everything is working just fine.
  1. MKV guide, Play MKV, MKV to AVI, MKV to DVD, MKV to MP4, MKV to Blu-ray
    By Baldrick in forum Newbie / General discussions
    Last Post: 2nd Mar 2012, 15:25
  2. GUI to convert Matroska (*.mkv) To AVI
    By qwerty9876543 in forum Linux
    Last Post: 17th Mar 2008, 21:38
  3. Searching for matroska/MKV Codec
    By moviebuff2 in forum Newbie / General discussions
    Last Post: 26th Dec 2007, 09:54
  4. Problem playing .mkv (matroska)
    By mk2006 in forum Newbie / General discussions
    Last Post: 18th Aug 2007, 04:33
  5. Conveting .MKV(Matroska) to AVCHD Disc/HD DVD-5
    By carlitos287 in forum Camcorders (DV/HDV/AVCHD)
    Last Post: 13th Aug 2007, 21:22
