Glad if anybody who understand about HDV technology can help...![]()
Is there any such tape for HDV camcorder? Or only miniDV tape is available for use? Will the quality be lost if a miniDV is used for recording in a HDV camcorder, set to record in HDV mode and subsequently capture for editting? I am using Adobe Premiere Pro 1.5.1 (with HDV plugin). What must I do to preserve the HDV high quality video during editting and exporting into a wmv format?
Please advise and thanks for your advise!
Thread: HDV Tape?
You can record on regular DV tape, however, Sony makes a tape especially for HDV recording which they claim has the following advantages:
90% fewer errors due to 40% increase in carrier-to-noise ratio*
50% fewer dropouts*
50% less tape shrinkage*
3db higher carrier-to-noise ratio*
http://www.sonystyle.com/is-bin/INTE...nkMedia_MiniDV
Sony has just announced a new 85 minute tape for HDV recording, but it's much more expensive. I don't know if it has any advantages over the 63 minute tape (other than length) or not:
http://www.camcorderinfo.com/content...niDV-Tapes.htm
I have never used anything except the the 63 minute tape for HDV as I figure if I'm going to go to the effort to shoot HDV, I ought to use a better than average tape. I've never experienced a dropout or other problem with it that I know of.
Thanks for the advise! Will check it out. Have a nice day!
Simple way to print HDV to tape
By stantheman1976 in forum EditingReplies: 6Last Post: 7th Aug 2011, 16:11 -
Retaining HDV scene split on tape?
By Undead Sega in forum Camcorders (DV/HDV/AVCHD)Replies: 0Last Post: 6th Oct 2010, 09:18 -
Can't capture from HDV tape!
By frlane in forum MediaReplies: 8Last Post: 2nd Jul 2009, 15:43 -
HDV tape stock recommendations
By kippard in forum Camcorders (DV/HDV/AVCHD)Replies: 15Last Post: 20th May 2008, 15:52 -
How much longer can tape-based HDV hang on?
By Ollie6431 in forum Newbie / General discussionsReplies: 18Last Post: 1st Feb 2008, 10:55
Statistics
Newest guides
Latest tool updates
New media comments
