does anybody know of a program that will convert AC3 6 channel to AC3 2 channel.
DVDit won't accept 6 channel and alot of movies don't come with 2 cnannel anymore.
A) Sonic Foundry Soft Encoded 1.1. Bad part is good luck finding it, it was discountinued awhile ago..last place I saw link was over at those a$$holes site at VCDsp.com
B) Dump DVDit, and get DVD Maestro/Virtuoso, DVD Wise, or Scenarist or a few others that handle 5.1 AC3.
Go to google.com, type Sonic Foundry Soft Encoded 1.1 and there is a xoom.it site with a demo of the program
Thanks Guys but I can't make it work. Every thing I try to do it says it's not supported by the demo and I don't have a crack. Am I missing something or do I need a cack to make this work.
Try SpruceUp. I've tried it and it works perfect with AC3 audio. The only thing is that there is only a demo available. But check http://www.astalavista.com for more.
ORB.
Batch Convert 6 channel AAC to AC3?
By massarosareloud in forum Video ConversionReplies: 11Last Post: 22nd Oct 2011, 14:41 -
How to convert a 6 channel aac to ac3?
By nasdravi in forum AudioReplies: 11Last Post: 15th Feb 2010, 22:01 -
DVD with mono audio channel...can i convert to two channel
By maass in forum Newbie / General discussionsReplies: 3Last Post: 1st May 2009, 21:46 -
Convert stereo ac3 with bad channel to mono ac3
By chipsndukes in forum AudioReplies: 7Last Post: 5th Nov 2008, 11:23 -
Convert single channel to double channel audio ...
By tariq_niazi in forum AudioReplies: 3Last Post: 15th Nov 2007, 16:47
