hello,
who can help me make my bose gsx regin free, ore at least tel me
how i can figure out what firmeware my systhem has
best regards
roy heffels
Thread: bose gsx
First off, your best bet is to get rid of the Bose, you can get a lot better for less money.
They, look through here for a good region free dvd player. You'll have regioni free then and for a lot less money and it will sound a lot better too.
Good luck with it all.
http://www.smartgroups.com/group/group.cfm?GID=3467186
has the region free codes and how to do it"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650)
321II, 321GSII & 321 GSX firmware display inforamtion procedure
Viewed on 321II & 321GSII console displays Steps 1 - 14
Viewed on 321 GSX console displays Steps 1 - 18
Obtaining System Information from the Media Center Display
You can obtain system information directly from the media center display by pressing
a few buttons. Follow the steps below.
- With the media center off, press and hold the ENTER/STORE button on the media
center. When holding down the ENTER/STORE button, pressing the ON/OFF button will
bring up the console system information on the console display.
- For each additional press of the ON/OFF button, you will get additional
information. See the list below.
- Once you are done viewing the information, press the POWER button.
01 - Video output : (NTSC Progressive -> NTSC Component -> NTSC Composite+S ->
*MULTI Progressive -> *MULTI Component -> *MULTI Composite+S ->
*PAL Progressive -> PAL Composite+S -> PAL Component)
[use the volume buttons to cycle through options]
* Added by Extensions Firmware Upgrade
02 - Flash Commit [press volume up to reboot]
03 - Console Software: (version)
04 - Console Variant: (#)
05 - Bass Box Software: (version)
06 - Tuner Sofware: (version)
07 - Console serial number: (s/n)
08 - Main Board serial number: (s/n)
09 - Tuner serial number: (s/n)
10 - DVD Region Code: (#)
11 - DVD Drive: (firmware version on first line)
(DVD model number on second line)
12 - Main Board Functional: (test results)
13 - Tuner Board Alignment: (test results)
14 - Serial Port: (Smart Speaker -> ETAP)
15 - Hard Drive: (firmware version on first line)
16 - Hard Drive Self Test: (test results)
17 - Gracenote Databese: (version)
18 - Eithernet Address: (Address)"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650)
Bose 901 MK4
By blinky88 in forum AudioReplies: 10Last Post: 1st Apr 2012, 09:48 -
DVD disc problem on Bose 3.2.1
By grandsire02 in forum Newbie / General discussionsReplies: 4Last Post: 28th Jan 2011, 12:45 -
Why does my Bose 3-2-1 play PAL DVDs?
By sandywood in forum DVD & Blu-ray PlayersReplies: 6Last Post: 29th Dec 2009, 12:08 -
Bose 321 GSX How to make it region free?
By wouter3 in forum DVD & Blu-ray PlayersReplies: 0Last Post: 1st Nov 2008, 07:23
Statistics
Newest guides
Latest tool updates
New media comments
