    Hello!
    I have some NRG files and they are not that big, around 400mb each.
    And I want them all on on DVD in AVI format.
    I have NERO 6 and I only can burn one little NRG to ISO file on disc not more that is the problem.....
    I'm pretty new in this stuff, does anyobody know a good converter, to convert NRG into AVI?
    Greetz
    An NRG file is a Nero image file. You can use DeamonTools to open them as virtual CD drives so you can extract the content to your HDD, and from there convert or group them as necessary. They do not need to be converted to avi files, just extracted.
    Read my blog here.
  3. Member Cornucopia's Avatar
    NRG is a disc image file like ISO.
    Mount with daemontools or NeroImageDrive and copy the files you need to the Harddrive.
    Once you've got enough for a disc, either make a Data disc compilation, or Reauthor a compilation DVD (depending on your expectations).
    edit: dangit! gunslinger, you're a quicker draw than I am!
    I also have Daemontools, but I never used it, and a friend explained it, but didn't know...
    I try now to mount, and I can mount all NRG files, not only one right?
  5. Always Watching guns1inger's Avatar
    You can mount several at a time by creating different virtual drives, or one at a time. It is up to you.
    Read my blog here.
  6. Member majchers's Avatar
    DEAMON tools mounts NRG in the original DVD SIZE. An AVI produced from this source is of the same (roughly) size - way, way too big (in GB) to fit onto regular size CD (in MB).
    How can I reduce it so it does fot on CD ?
  7. I'm a MEGA Super Moderator Baldrick's Avatar
    How did you create the avi?
    Use autogk to make an avi divx/xvid with custom file size, you just load the dvd/file and then set the output file size and convert.
