VideoHelp.com Forum
    Has anyone ever tested the quality of Ulead DVD WS internal encoder (or DVD-Shrink's) vs. DVD-compliant encoding with CCE? I wonder if it is really necessary for me to encode hundreds of mpeg-2 files created with Sony Vegas in CCE (already DVD-compliant but need to reduce their size) vs. just using them directly as assets in Ulead DVD WS and have the final job reduced in size there. Another option would be to author on the hard drive and then use DVD-shrink to reduce the size and burn so that it fits on a DVD. From what I have heard/read, CCE is superior to any DVD-authoring software (or DVD-Shrink, CloneDVD etc.) when it comes to encoder quality and speed.
    If they are only slightly larger than they need to be, Shrink my be the better option. Certainly faster than encoding, it depends on how compressed the originals are as to whether it will look good, bad or indifferent.
    What is the total combined running time of the movie on each disc ?
    Read my blogs here and here. Change England's Libel Laws - Sign Here
    I don't know yet. Basically I have 195 episodes. Each episode is about 10 minutes, so that's approx. 30 hours. It would be great if I could reduce the filesizes such that I can put them on <= 10 4.7GB DVDs.
    DVD Shrink is NOT an encoder.
    Ulead uses a MainConcept engine for the encoder.
    Reducing the size is not a good idea in most cases. What about DL media?
    DL is an option. How does DVD Shrink adjust the project filesize if it doesn't re-encode?
    It transcodes. It alters the data without decoding or encoding.
  1. Cinema Craft Encoder Sp 2.67.00.27
    By Gwar in forum Video Conversion
    Last Post: 19th Feb 2012, 11:32
  2. Problem with Cinema Craft Encoder SP and Windows 7
    By echo1434 in forum Video Conversion
    Last Post: 24th Dec 2011, 16:51
  3. Cinema Craft Encoder Picture Quality
    By pboong in forum Video Conversion
    Last Post: 23rd Aug 2010, 23:17
  4. Help with Cinema Craft Encoder
    By Topcat360 in forum Video Conversion
    Last Post: 29th Jan 2008, 16:51
  5. Cinema Craft Encoder Plugin
    By MI6 in forum Video Conversion
    Last Post: 11th Aug 2007, 18:05
