I am now using a MacBook and found I can't convert rmvb to others format due to unknown reason.
After I'd searched, I want to know if it is my problems only or it is not working?
I found the version of reallib is a little bit old and I suppose it would not be a UB library.
Any idea?
Thread: reallib - Mactel compatible?
Originally Posted by MacJuJu
There is an MacOS X x86 version of the reallib on the mplayer website. As I don't own an Intel based Mac, I don't know if they will work with ffmpegX or if they include all the needed codecs, but it worth the try.
Note that it's probaly an install package. It will install a "codecs" folder in /usr/local/lib. Rename this folder to "reallib" and try to put it in the /Library/Appplication Support/ffmpegx folder.Jean-Philippe Schuck
Un générique, un autre jour, le blog sur les génériques de dessins animés
OHHH!!! THANK YOU THANK YOU THANK YOU. I have been searching for a version of reallib that actually -WORKS- on my core duo since I got it back in may, and this does the trick! THANK YOU SO MUCH!
Is my computer compatible?
By Immensible in forum CapturingReplies: 9Last Post: 17th Nov 2011, 16:36 -
Reallib package installation doesn't work for me
By caixiaoeva in forum ffmpegX general discussionReplies: 18Last Post: 30th Oct 2010, 15:20 -
can't play rm in mplayer on mac osx--did install reallib codecs
By onesuch in forum MacReplies: 2Last Post: 20th Dec 2007, 00:56 -
Vista compatible?
By Slowburn in forum DVD RippingReplies: 2Last Post: 14th Jun 2007, 10:55 -
Latest OS X reallib binaries?
By Scallywag in forum ffmpegX general discussionReplies: 1Last Post: 3rd Jun 2007, 17:26
Statistics
Newest guides
Latest tool updates
New media comments
