I have a new DVG-3000N and after a lot of searching, I found how to get to the "factory" menu. BUT I noticed it looks like the menu I would see on a DVG-5000N. Being the suspicious type I checked the version number reported in the “factory” menu. It read V25212133. When I peeked at the Mvision hack on the dvd-wizards site I found that the “original” and hacked update files were V25212131 (2 versions old). ALSO the DGV-5000N has V25212134
Since my player seems OK with variable bit rate MP3s and subtitles in SVCD (reported NOT to work by other reviewers) I am certain that I don’t want to apply the hack as I will probably loose these features.
Does any one know of a source for this version?
... a source for a hack in this version?
... How to build the files for the CDR?
... How to apply the hack to the data?
... Is the EEPROM in a socket so I could remove it and read it?
My player seems to be a DVG-5000N without the power button on the remote![]()
THANKS in advance
PS: and thanks for this site!
Sory if this a dupe question, but the search feature is down.
<font size=-1>[ This Message was edited by: cread on 2002-01-10 20:40:42 ]</font>
Another Update: I have found a file that has V25212133:
Its for a DVG-9000N (as posted on DVD-Wizards)
Could this be the same?
<font size=-1>[ This Message was edited by: cread on 2002-01-11 21:19:53 ]</font>
Results 1 to 1 of 1
AVG 8 updates?
By wulf109 in forum ComputerReplies: 2Last Post: 3rd Feb 2009, 09:49 -
Peerguardian updates to 0. Anyone have the same problem? Thanks.
By gary11364 in forum ComputerReplies: 4Last Post: 10th Apr 2008, 14:03 -
strange updates
By Tom in HD in forum MacReplies: 1Last Post: 19th Feb 2008, 20:29 -
Code Free does not work daewoo dvg 8300 se
By ramona in forum DVD & Blu-ray PlayersReplies: 1Last Post: 4th Feb 2008, 10:52 -
Automatic updates?
By fLYtRap in forum ComputerReplies: 11Last Post: 13th Jul 2007, 16:46
