Converting VHS to DVD under Linux HOWTO
by Dan MacDonald, 24th August 2006
This document assumes you have:
A computer with a fast CPU (2Ghz+ if you want to encode straight to MPEG2 in software with no dropped frames) running Linux with at least 10GB free drive space.
Basic knowledge of Linux (how to install programs, use the console etc.)
A VCR
A video capture card supported by Linux (see http://linuxtv.org/v4lwiki/index.php/Main_Page )
A DVD burner
The programs tvtime, varsha, k3b and mencoder (which is part of mplayer)
You may also need a SCART to COMPOSITE cable and a stereo RCA to 3.5mm jack audio cable
The best way to capture analogue video under any operating system is with a firewire analogue video adapter such as Canopus ADVC 110. This supposedly gives much better picture quality than most of the PCI capture cards but these adapters are still quite expensive at the time of writing. If you plan to do a lot of analogue video capture then it may well be worth the extra cost. Under linux you could then just use dvgrab to capture from one of these but I'm not covering that method here.
The first step, of course, is to connect your VCR to your PC. Most TV capture cards have three types of video input: s-video, composite (the yellow one) and TV aerial. s-video gives the best quality of the three so use that if you can. I have an Avermedia TV Capture 98 PCI capture card which is based on the bt878 chipset. The picture I get with this card is quite grainy and I hear that the saa713x chipset capture cards are supposed to be much better- see the v4l2 wiki link above for card recommendations and compatibility. Another thing about this card is that I couldn't get it to find my VCR signal through the aerial connector and so I had to use a SCART to composite cable.
After plugging your VCR into your PC (including running an auxiliary cable from your VCRs sound outputs to your PCs mic in) insert a VHS tape, push play and start tvtime to check you are getting a picture and sound. If you are trying to get a picture through an aerial cable then you will probably have to scan through the channels but this isn't normally neccessary with composite and s-video. If there is no sound then you will need to open your mixer program (like alsamixer) and turn up the mic input levels.
From here on I'll be talking about using tvtime but if you have xdtv (xawdecode) installed you can use that instead to preview your analogue video input. I'm using mencoder here as I haven't yet worked out the exact settings to capture directly to a DVD-compliant MPEG2-PS file using xdtv, which would be a much nicer way of doing things for GUI fans. Also, if your computer isn't fast enough to be encoding direct to DVD res MPEG2 under mencoder then you'd be better off capturing your footage under xdtv to a MJPEG format avi file. MJPEG avis can be loaded into both Cinelerra and DeVeDe.
Once you have a picture with sound under tvtime then you are ready to start capturing. If your tape is at the right point then you can shut tvtime now. Open up a console, change into the directory where you want to save your video (you will need a few GB free if you're doing a full tape) and then copy/paste one of the following three commands into that console
PAL LOW (VCD QUALITY) RES CAPTURE
mencoder -tv norm=PAL:driver=v4l2:width=352:height=288:input=1: fps=25 tv:// -oac lavc -ovc lavc -of mpeg -mpegopts format=dvd -vf pp=lb/ha/va/dr,hqdn3d,harddup -srate 48000 -af lavcresample=48000 -lavcopts vcodec=mpeg2video:vrc_buf_size=900:vrc_maxrate=150 0:vbitrate=1300:keyint=15:acodec=mp2:abitrate=192: aspect=4/3 -o capture.mpg
PAL MEDIUM (SVCD QUALITY) RES CAPTURE
mencoder -tv norm=PAL:driver=v4l2:width=352:height=576:input=1: fps=25 tv:// -oac lavc -ovc lavc -of mpeg -mpegopts format=dvd -vf pp=lb/ha/va/dr,hqdn3d,harddup -srate 48000 -af lavcresample=48000 -lavcopts vcodec=mpeg2video:vrc_buf_size=1500:vrc_maxrate=30 00:vbitrate=2500:keyint=15:acodec=mp2:abitrate=192 :aspect=4/3 -o capture.mpg
PAL HIGH ('DVD' QUALITY) RES CAPTURE
mencoder -tv norm=PAL:driver=v4l2:width=720:height=576:input=1: fps=25 tv:// -oac lavc -ovc lavc -of mpeg -mpegopts format=dvd -vf pp=lb/ha/va/dr,hqdn3d,harddup -srate 48000 -af lavcresample=48000 -lavcopts vcodec=mpeg2video:vrc_buf_size=1500:vrc_maxrate=80 00:vbitrate=7000:keyint=15:acodec=mp2:abitrate=192 :aspect=4/3 -o capture.mpg
As soon as you push enter the capture process will begin, to end it push CTRL+C.
It is important to note that the above commands are for capturing PAL (European) video from a composite input. If you use NTSC videos (like in America and Japan) then you have to change the norm value to ntsc, the fps value to 29.97 and you would use these width/height values instead:
720 x 480 high res
352 x 480 medium res
352 x 240 for low res
If you're capturing through the aerial, change the input value to 0 (or 2 for s-video).
'-vf pp=lb/ha/va/dr,hqdn3d,harddup' is the video filter setting to clean up a grainy picture. If you have a better quality capture card than me then you should be able to get away with just '-vf harddup' instead. Using fewer filters will mean less stress on your CPU of course.
The main value you may be interested in altering is vbitrate. You can lower the bitrate to shrink the size of the video file and fit more video onto your DVD but this of course also degrades the quality and puts greater strain on the CPU when encoding. Don't expect all DVD players to be able to handle a vbitrate greater than 8000 though.
On my AthlonXP 2000 (which is of course really 1.7Ghz) I can capture a full 25fps @ 352x576 with stereo sound and no dropped frames on certain footage but if there is lots of motion it tends to average about 20fps which is also the framerate it maxes out capturing at the high res setting.
Now that you have an .mpg file of your video you should try playing it under mplayer or xine to check that it is OK. If its fine then you can load varsha and create a DVD iso file with it which in turn can be burned with the burning program of your choice such as k3b.
If you want to know more about mencoder's options then you should read the manpage or the online documentation at
http://www.mplayerhq.hu/DOCS/HTML-si...n/MPlayer.html
Good luck!
dan
Results 1 to 20 of 20
Thank you for this great info. I will use this as a guide and test it sometime soon. My capture card is also a BT878 chipset, so I hope for good results. I just happen to have a bunch of Hi-8 I need to capture sometime in the very near future.
np tekkieman! Its good to know I've already saved at least one person potentially days of hassle and experimentation like I went through.
As you can see, the process I described above is entirely graphical, point+click apart from the actual capture part. Before being forced into figuring out that mencoder command I tried a few different mencoder GUIs but none of them worked, at least not for doing what I wanted. It would be good if tvtime could integrate capture features.
If anyone knows of a nice mencoder GUI for Linux that can capture from a v4l device to DVD MPEG2 (and VCD MPEG too pref.) that WORKS then please let me know!
Thanks!
I just edited the above HOWTO to reflect that you probably need a 2Ghz+ CPU if you want to record straight to DVD MPEG2 without dropping any frames under most conditions.
There is a graphical analogue video capture tool for Linux that works (a bit) - gv4l, but it uses transcode not mencoder . If I use its ffmjpeg codec and turn the de-interlace option on I get smooth, fantastic image quality captures at up to 720x576- the problem is that the sound is out of sync. I've read that this could be because it is compressing the audio so I've tried using 'ffmjpeg,wav' 'ffmjpeg,raw' or 'ffmjpeg,pcm' in the 'encode codec' box as I read somewhere but that doesn't work so I've wrote to the programs author to see if he can help.
I'd really like to get this sorted as this would seem to be the best option for transferring some analogue video to DVD under Linux for people like me whose CPU isn't quite fast enough for real-time MPEG2 encoding. Soon as I we get this sorted out I'll update this HOWTO with a second method with 2 encoding steps (gv4l -> DeVeDe) instead of one.
This is the same problem I had with gv4l. Audio out of sync. After weeks & week of trying everything writing the author (I did get a respose) I still couldn't get it to work correctly.
I finally gave up on it. I then bought a PVR-250 card & did a dual boot with KnoppixMyth.
I capture directly to DVD format with no dropped frames at a full 720x480 even accross a network.
Now When I need to capture any video I reboot in KnoppixMyth and do my capture.
Great news - I found it!!!
Yes, there is a graphical analogue video capture tool for Linux that really DOES work, its called
xdtv
which is short for xawdecode. As you might guess from the name, it is basically a souped-up XawTV with many more options for video capture. I find it strange that xdtv is five years old now but not one of the hundreds of web sites, forums and documents about Linux video capture that I read mentioned this program. Hundreds (thousands) of people have read this guide in the last few days and it would seem none of those people knew about it either. The other strange thing about this is how I found it- under the Multimedia/Video section of kde-apps.org and it is obviously neither a QT or KDE app!
I'm happy with my Linux video setup now as xdtv can capture perfect quality 704x576 MPEG2 or MJPEG video @25fps on my AthlonXP with NO frames dropped- yeah! I now just need to see if I can get it to produce DVD compliant MPEG2 files...
Thanks for the guide. My only comment is that capturing straight to mpeg will make the video tougher to edit, if you want to remove commercials, or extra stuff you don't want. (many editors botch the a/v sync with mpegs)
If you capture to something other than mpeg, then you can do it on a slower machine too
For capturing, I use mjpeg tools:
http://mjpeg.sourceforge.net/
It comes with a lavrec command that can be used to capture video to an avi. It can then be edited with the included glav tool or with something like avidemux.
mjpeg tools also comes with tools to convert to MPEG, and various filters, but I find mencoder is faster for this task.
I've tried various programs for this task, and the above is what works best for me so far.
I used to find this too, but my experience with dvbcut (which I mentioned in another thread on this subject) has been that it does truely an excellent job of retaining audio-video sync. Do you experience problems with it also?Originally Posted by uth
I couldn't get either lavrec or glav to work but I agree that MJPEG would be a better choice of capture format if you wanted to edit too. In fact thats the format I've been capturing to under xdtv before I use DeVeDe to make a DVD image out of the avis. I can confirm that MJPEG avi's captured with xdtv open fine under Cinelerra
I wrote to both the author and mailinglist for xdtv asking if anyone knew the correct capture settings to record to a DVD compliant MPEG2-PS file but I've had no response. The plan was to re-write this tutorial based around xdtv but looks like that will have to wait until someone does some experimentation to discover the correct settings.
It looks like xdtv/ xawdecode still hasn't been added to the list of Linux video tools yet- might have to write another mail to the maintainers as I think its an important addition/ big omission.
I just wanted to say that mpegs created with mencoder the way presented in this thread, are almost ok to be imported in mainactor.
There are only some "minor" problems which I reported in an unofficial mainactor forum.
http://mainactor.flavor8.com/index.p...25.msg44#msg44
and thanks for this howto
visit SPAM and transfer your home video tapes to dvd. You can get a pretty good conversion at a reasonable price from a lot of places. But what are most of these companies lacking? Care and attention to detail! Other ways you get totally amateurish product done with domestic equipment.[/url]
Okay,
danboid said you need to install "the programs tvtime, varsha, k3b and mencoder (which is part of mplayer)" in order to capture VHS onto DVD media. The hardware is set up and I've been converting these tapes to DVD in Windows but I want to do it in linux.
Having trouble getting off the ground here. Via synapitc package manager I installed all the programs danboid suggested in my Ubuntu 6.06 system with a SAA7134 based video capture card. Varsha don't even show up in the Applications menu. TVtime does show up, however, but when I click on the menu icon, TVtime doesn't load. Danboid says the starting point is getting a signal in TVtime. Well, I can't even get TVtime to open. Can anyone help?
Thanks, Steve
Hi Danboid,
I have used mencoder in the way you described; the video quality it's pretty good, but the audio gives me some problem of noise.
To give you an idea of this, it is similar to a mp3 with a very low bitrate.
Which option of mencoder must I modify ?
Thank you so much
I have solved this audio noise problem, adding: alsa:audiorate=128000
Thanks however!
Is there any diffrence in PAL (Australian) fps. I have tried to copy using the commands but am getting poor picture quality.It is important to note that the above commands are for capturing PAL (European) video from a composite input
I found this HowTo really helpful. The only problem I've had is that I couldn't record audio. I'm using a Hauppauge ImpactVCB capture board, and feeding the audio into the Line In jack on my motherboard, and I'm running Fedora 9.
The problem was that the alsa mixer wasn't set to capture from Line In. Entering
amixer -c 0 sset Line cap
solved it.
Thanks.
Very strange - I uploaded the terminal listing but it didn't show against the message. Now it shows.
Linux themed skin for DVD Rebuilder (for Ubuntu and Generic Linux)
By freebird73717 in forum LinuxReplies: 5Last Post: 26th Nov 2008, 20:27 -
rmvb to avi in linux command HOWTO ! ?
By Gilberts in forum LinuxReplies: 1Last Post: 24th Oct 2008, 20:07 -
Converting Video for the Zen (HowTo & Script)
By Airjrdn in forum Video ConversionReplies: 1Last Post: 9th Jul 2008, 19:01 -
Converting WAV to AAC -- am looking for some howto methods, etc.
By vhelp in forum AudioReplies: 7Last Post: 12th Apr 2008, 14:55 -
Nero Linux 3 Delivers Blu-ray and HD DVD Data Burning Support to Linux OS
By BJ_M in forum Latest Video NewsReplies: 0Last Post: 28th May 2007, 10:23
Try using -ovc copy -oac copy... After capture you will get a HUGE video. All that you need to do is recode it and delete the original HUGE capture video file.
