VideoHelp.com Forum
    Ok so I converted some avi files to dvd format using winavi, then I ran them through dvdlab to make them all pretty, then I think I had to shrink them onto a dvd using dvdshrink. I watched these files on my dvdplayer 2 weeks ago, they were fine, I went to watch them last nite and now the audio doesnt match up, whats going on? Why would it do that? I used quality settings for everything and I didnt burn it at a high speed
    try the dvd on your computer with software dvd player, same sync problems ?
    yes if i run it on my pc and play using vlc media player it does the same thing, why is this happening?
  4. Member SingSing's Avatar
    Digital information don't degrade or change. It either works or fails. the audio sync problem was always there, you just did not notice it 2 weeks ago.
    I highly doubt that since its like 30secs off
  6. did you by chance put a stomped label on it? You can run into some issues with the playback of dvd's when a label is placed on the DVDR. I've also seen macro blocks during playback too.
    Yes. 8)
  8. BuskerAlley.com zoobie's Avatar
    Next time, go near the end of it and check for sync. You're not the only one who hasn't noticed this as I've seen this happen on major tv channels like the History channel and even AMC once or twice.
    Author, Producer, Composer, Director - Sony HDV, Konica SLR, LG BD burner
    Handcoder: HTML, PHP, JS, CSS - In Production: Busker Alley - The Movie
  1. Baffled by this one guys 'n gals....
    By TheGMan in forum DVD Ripping
    Last Post: 8th May 2008, 07:21
  2. Killed my DVD recorder
    By Kschossi in forum DVD & Blu-ray Recorders
    Last Post: 8th Mar 2008, 22:57
  3. Baffled by conversion problem
    By vvw in forum DVD Ripping
    Last Post: 25th Feb 2008, 13:14
  4. Shrek killed my dvd decrypter!
    By blaqlion22 in forum DVD Ripping
    Last Post: 18th Dec 2007, 17:35
  5. Replies: 16
    Last Post: 25th May 2007, 12:02
