VideoHelp.com Forum
Results 1 to 18 of 18
  1. Member waheed's Avatar
    Everytime I open Firefox, the window is opened minimised by default and I have to click on the maximise icon to have firefox fill the screen.
    This happens every time I open firefox, and even a new window in firefox.
    Does anyone know what settings I need to change so firefox is opened maximised by default. Tried googling the answer but couldn't find any.
    Thanks.
  2. VH Veteran jimmalenko's Avatar
    http://www.no-future.com/erutufon/sh...ad.php?t=21187 mentions a corrupt profile, but I dunno whether this would be contributing to the non-maximised issue though.
    http://www.webuser.co.uk/forums/show...38/an/0/page/1 - sounds promising !
    If in doubt, Google it.
  3. Member waheed's Avatar
    Thanks for the reply jim.
    The problem is the first link is exactly the problem I had as mentioned by the OP, reading through the responses however didn't provide a solution.
    The second link actually solved the problem. All I had to do was to right click on the firefox shortcut and select Run as maximised window.
  4. VH Veteran jimmalenko's Avatar
    I googled better
  5. Member waheed's Avatar
    Only a temporarly fix (for the firefox shortcut that is) . It opens maximised when I click on firefox shortcut, but when within firefox and I click open new window, the new window opens minimised so still need to maximise it
    I had the same problem. Try this. Open Firefox, then maximize. Then click on the center button which enables you to manually size the window. Resize to fit your screen. Close and see if will open to the manually sized window when opened again. Good luck.
    wwaag
  7. Member waheed's Avatar
    Didn't work. Though Firefox is a good browser, this is not the first time ive had this problem. Ive had this exact same problem many times before and was required to unistall and do a clean install.
    Ive just installed Opera and have now decided to use Opera.
  8. BuskerAlley.com zoobie's Avatar
    Dunno if this works with other browsers but I max the window then hold ctl + close the window.
    Author, Producer, Composer, Director - Sony HDV, Konica SLR, LG BD burner
    Handcoder: HTML, PHP, JS, CSS - In Production: Busker Alley - The Movie
  9. Member waheed's Avatar
    Tried that. Doesn't work.
    Haven't had that problem, but 99% of the time I open a new tab rather than a new window anyway- I consider tabs a major plus of Firefox over IE.
  11. Member gadgetguy's Avatar
    Just a thought. Does it actually come up minimized or is the window just shrunk to nearly nothing? For me Firefox always opens to Windows Standard (resizable), not Maximized, but it always comes up to the same size as the last time I resized it. Does anything appear on the desktop when you open up a new Firefox window? Or just the icon in the taskbar?
    Buy My Books
    Type :
    about:config
    ..in the address bar and hit enter. See if there's an internal setting.
    Alan
  13. Member waheed's Avatar
    @ gadgetguy
    Firefox actually comes to minimised as a small window so I need to maximised it everytime to fill the screen. I always opens uo to the same size, regardless of whether I resize it or even maximise it.
    @Alan69
    Typed that, gone throgh the list and cant really find an option of size maximisation.
  14. Member gadgetguy's Avatar
    Don't maximize it, resize it. Grab a corner and expand it out to full screen instead of using the maximize button.
    Buy My Books
  15. Member waheed's Avatar
    Tried it. Doesn't work. I think theres a corruption within Firefox which is causing the problem.
  16. Member SanderMan's Avatar
    Did you try making a new profile? Maybe there's a corruption somewhere. See http://www.mozilla.org/support/firefox/profile for more info.
  17. Member waheed's Avatar
    Creating a new profile didn't work, though it earsed all my bookmarks, and other settings.
    Ive just uninstalled Firefox, cleaned the registry, and did the clean install. This is the only way I could think of fixing the problem. All is well now (for the timebeing). This is not the first time ive had the problem. Had it a few times before as well as also did clean installs previously. I think it would also be inevitable that this problem would occur again in the future unless the bug in firefox is fixed
    Thanks for all those who helped. Much appreciated.
  18. VH Wanderer Ai Haibara's Avatar
    I archive certain files in my profile on occasion, such as bookmarks.html, history.dat, etc. If you have to delete a profile and start over, you can copy the above two files into the new profile, and not lose your bookmarks or history. (I usually don't copy anything else, even though it can be done, because I might carry over whatever problem I caused to the original profile. )
    I always thought (not that I'm doubting the problem you're having, it's just what I'd thought) that on Windows, Firefox's window state (minimized, maximized, etc.) was left mostly to Windows to handle. I think there's something else Windows looks at to remember window states (even in spite of what a shortcut tells it to do), but I don't recall what it is.
  1. maximising quality on S-VHS to DVD conversion
    By Tafflad in forum Restoration
    Last Post: 16th Dec 2009, 07:04
  2. Maximising BITRATE
    By mrj03 in forum Authoring (VCD/SVCD)
    Last Post: 28th Oct 2009, 20:14
  3. Firefox?
    By AM3 in forum Computer
    Last Post: 23rd Apr 2008, 12:35
  4. Firefox ?
    By makntraks in forum Computer
    Last Post: 8th Feb 2008, 12:34
