i skimmed through the sticky but couldnt find my problem, i have a tape from a while back like a late 80's weekend cartoons recording and i found it today and stuck it into the vcr, to my surprise it still works but the audio sounds like someone vibrating their vocal chords into an anoying echo-y effect, is there a way to restore it or is it lost forever? thanks for the solution in advance
Thread: vhs restoration question
If it is the HiFi audio track, try adjusting the tracking. If that doesn't work see if your VCR can use the linear (mono) track. If it is the mono track that sounds like that, see if the edge of the tape is ruffled. If the tape isn't ruffled, and you are using the mono track, clean the VCR.
Wonderful advice. I think that basically covered everything.Originally Posted by olyteddy
Answers to Common Video Questions:
Best blank discs • Timebase Corrector FAQ • Best VCR for capturing • Help restoring video
VHS Restoration
By Asesinato in forum RestorationReplies: 239Last Post: 25th Apr 2012, 21:11 -
old vhs restoration
By ishwinderjauhar in forum RestorationReplies: 16Last Post: 24th Sep 2011, 09:03 -
old VHS restoration
By pirej in forum RestorationReplies: 66Last Post: 8th Jun 2011, 09:19 -
VHS restoration
By degacci in forum RestorationReplies: 5Last Post: 5th May 2008, 02:02 -
VHS-C restoration
By dlarry in forum RestorationReplies: 10Last Post: 25th Sep 2007, 21:14
Statistics
Newest guides
Latest tool updates
New media comments
