VideoHelp.com Forum
  1. This is werd. When I try to join a bunch of files in tmpgenc. When I do them with lame mp3 encoded audio the audio goes out of sync. When I do individual files its ok. Ideas?
  2. Member teegee420's Avatar
    The short answer, TMPGEnc isn't good at joining files, particularly if it's variable bitrate audio. You're better off converting them individualy first, then join them using the Merge and Cut feature in the MPEG Tools menu. Just a warning though, TMPGEnc doesn't always do a good job of that either. It might work fine for shorter clips.
  3. I see. Is there a good program for just joining video clips? I've got a bunch.
  4. Member teegee420's Avatar
    Zealot All Video Joiner might be your best option. It's easy to use and it lets you join multiple file types too. The only thing is that it re-encodes everything, so there will be some quality lost.
  5. Nice program. Can you tell me how to use divx or xvid with it? All I can do is get ffdshow and it only gives me like 1 frame.
  1. audio sync problem, how to work out progressive audio sync delay
    By jolt321 in forum Newbie / General discussions
    Last Post: 10th Apr 2012, 21:09
  2. Audio out of sync when using LAME ABR
    By muffinman123 in forum Audio
    Last Post: 3rd Oct 2011, 12:25
  3. Replies: 3
    Last Post: 6th Sep 2011, 07:54
  4. MP2 audio with LAME?
    By RogerTango in forum Audio
    Last Post: 3rd Nov 2009, 22:28
  5. To lame for HD?
    By rhythminmind in forum Media Center PC / MediaCenters
    Last Post: 10th Oct 2007, 19:38
