VideoHelp.com Forum
  1. Converting single vob to ipod h.264 "finishes" in 2 seconds.
    I used MTR to make a single VOB from my DVD.
    I can provide more data if this is not a known issue.
    On the bright side, it is converting my PSP h.264 (of the same film)
    to iPod h.264 nicely.
    If you need a piece of my video is required, let me know how to cut
    the VOB up.
    I use MPEG Streamclip (with Apple's MPEG2 decoder present) to save as QT (MJPEG-B, full quality, all other settings as normal). When done, drop that MOV into ffmpegX and encode for iPod H264. If the film is dark, you might alter the settings in MPEG Streamclip to boost brightness by about 20-25% and saturation by 30-40%. You may do a small portion of the original VOB in MPEG Streamclip and then run that through ffmpegX to verify that you're getting what you want before committing to the entire length of both conversions.
  3. Explorer Case's Avatar
    My guess is you do not have the QuickTime MPEG-2 playback component installed.
    iPod h.264 defaults to Decoding with QuickTime (Options tab), so it fails decoding the VOB file with this setting. Uncheck that option and try again. It should now then decode the VOB the same way as the PSP h.264 preset, hopefully with the same success.
  4. Thank you for the replies. ffmpegX "just works" so often I forget some of the obvious stuff. This has been helpful.
  1. VIDEO_TS to iPod H.264 and subtitles
    By veravera in forum ffmpegX general discussion
    Last Post: 9th Aug 2008, 15:39
  2. Ipod - h.264 or MPEG-4, which one is better?
    By FallenAngelII in forum DVD Ripping
    Last Post: 10th Jan 2008, 11:12
  3. converting to h.264 for ipod
    By nagihcim1 in forum Newbie / General discussions
    Last Post: 2nd Nov 2007, 08:27
  4. Converting AVI to iPod h.264 preset
    By oldskoolboarder in forum ffmpegX general discussion
    Last Post: 29th Oct 2007, 16:17
  5. single .vob in ffmpegX to h.264 (mencoder) .mp4 a/v sync issues
    By jabroni5 in forum ffmpegX general discussion
    Last Post: 7th Jun 2007, 16:48
