Hi,
I have a DVD9 with four movies on it. I want to divide them over two DVD5 DVD's and create a simple menu (main menu = select movie, then a chapter select menu with also a play all button).
Using DVD Shrink I divided the four movies in 2 DVD's containing two movies. I then imported them in DVD Author and created a simple menu just like I wanted. Problem is that DVD Author does not support subtitles!
What is the best way to proceed: do I create the DVD using DVD Author and add the subtitles afterwards and if so, how do I do this? Or should I use some other software?
I also tried DVDLab Pro but it is much more complex to create the menus and it does not support SUP files (which I get after demuxing the DVD). I do not want to convert the subtitles to SRT because I will lose formatting and spelling errors occur durin the OCR process.
Any help is appreciated!
Thanks,
Jeffrey
Results 1 to 1 of 1
changing the dvd menu by adding new subtitles
By mapostolro in forum Authoring (VCD/SVCD)Replies: 1Last Post: 21st Mar 2009, 09:05 -
Adding a menu to a DVD of music videos with no menu
By vtrop in forum Authoring (DVD)Replies: 1Last Post: 25th Feb 2009, 09:07 -
Adding a menu and selectable subtitles
By HAR in forum MacReplies: 0Last Post: 15th Sep 2008, 05:25 -
Adding several movies to one title/menu
By dread in forum Authoring (DVD)Replies: 1Last Post: 22nd May 2008, 22:25 -
Adding menu to DVD
By randyj in forum Newbie / General discussionsReplies: 1Last Post: 21st Dec 2007, 01:28
