VideoHelp.com Forum
    I have an avi file that was obviously converted straight from a PAL source to NTSC and seems to be "stretched" rather than properly converted. The audio on it sounds slowed down and low pitched. Its hard to say wether or not the video is the same way, but it looks like it plays okay. What I need to know is, how would I speed up the audio to its proper frequency and still have it sync with the video? I have tools like VirtualDub and AVIRecomp if its possible to use one of those.
    Thanks in advance to anyone who can help.
  2. Member FulciLives's Avatar
    It is proper to convert PAL which is 25fps to NTSC at 23.976fps which is a "slow down" and makes the running time in NTSC longer thus requires the audio to be "stretched" so it is also longer.
    The audio should be in sync from start to end (if it was done correctly) and the "pitch" change to the audio should really not be all that noticeable.
    If anything the audio was changed for the PAL and was "restored" by going back to NTSC. If any audio is "more correct" it would be the PAL to NTSC audio you now have.
    Unless someone really screwed up somehow the conversion.
    But based on what you said it seems like it was done correctly.
    - John "FulciLives" Coleman
  3. Mod Neophyte Super Moderator redwudz's Avatar
    If the audio really bothers you, you could try the freeware audio editor Audacity or similar to adjust the pitch, then add the altered audio back in. No guarantees that will work properly, so don't delete any original files till you are sure.
    Thanks for the replies. I'm not 100% sure it was a PAL conversion to NTSC, but that is what it sounds like. You can REALLY tell an audio difference in it. When a character speaking is NOT supposed to sound like a slow baritone, then you know something is definatly off. I'll give Audacity a try and see if that'll fix it. I just hope both the video and audio resync when its done.
  1. DV-AVI conversion to H.264 / MPEG2 - playback speed issue
    By howardmg in forum Video Conversion
    Last Post: 27th Jul 2011, 23:07
  2. Handbrake converted videos now 1/3 speed
    By zelman in forum Video Conversion
    Last Post: 4th Mar 2010, 04:48
  3. mkv2vob: VOB converted video plays at ~5x speed
    By shiroi in forum Video Conversion
    Last Post: 18th Jan 2010, 17:17
  4. converted AVI to VCD, but playback is too fast
    By LWC in forum Authoring (VCD/SVCD)
    Last Post: 21st Nov 2008, 21:55
  5. Playback of PAL DVD at correct speed ?
    By MacEachaidh in forum Software Playing
    Last Post: 19th Sep 2007, 00:02
