Hi all
Pressed Autocrop on an AVI PAL DV clip as setting up a flv conversion.
Hope this helps.
Date/Time: 2006-08-18 12:57:46.330 +0930
OS Version: 10.4.7 (Build 8K1079)
Report Version: 4
Command: mplayer
Path: /Library/Application Support/ffmpegX/mplayer
Parent: ffmpegX [293]
Version: ??? (???)
PID: 441
Thread: 0
Exception: EXC_BAD_ACCESS (0x0001)
Codes: KERN_INVALID_ADDRESS (0x0001) at 0x63840f63
Thread 0 Crashed:
0 libobjc.A.dylib 0x90a554c7 objc_msgSend + 23
Thread 1:
0 libSystem.B.dylib 0x9000a277 mach_msg_trap + 7
1 com.apple.CoreFoundation 0x9082a2f3 CFRunLoopRunSpecific + 2014
2 com.apple.CoreFoundation 0x90829b0e CFRunLoopRunInMode + 61
3 com.apple.audio.CoreAudio 0x9146441e HALRunLoop::OwnThread(void*) + 158
4 com.apple.audio.CoreAudio 0x91464239 CAPThread::Entry(CAPThread*) + 93
5 libSystem.B.dylib 0x900247a7 _pthread_body + 84
Thread 2:
0 libSystem.B.dylib 0x90049467 semaphore_timedwait_signal_trap + 7
1 com.apple.audio.CoreAudio 0x9147165c CAGuard::WaitFor(unsigned long long) + 212
2 com.apple.audio.CoreAudio 0x9147157e CAGuard::WaitUntil(unsigned long long) + 66
3 com.apple.audio.CoreAudio 0x9146fefa HP_IOThread::WorkLoop() + 690
4 com.apple.audio.CoreAudio 0x9146fc43 HP_IOThread::ThreadEntry(HP_IOThread*) + 17
5 com.apple.audio.CoreAudio 0x91464239 CAPThread::Entry(CAPThread*) + 93
6 libSystem.B.dylib 0x900247a7 _pthread_body + 84
Thread 0 crashed with X86 Thread State (32-bit):
eax: 0x63840f63 ebx: 0x925ea80e ecx: 0x90abc010 edx: 0x00000069
edi: 0x63840f6b esi: 0xbfffe8a8 ebp: 0xbfffe938 esp: 0xbfffe874
ss: 0x0000001f efl: 0x00010202 eip: 0x90a554c7 cs: 0x00000017
ds: 0x0000001f es: 0x0000001f fs: 0x00000000 gs: 0x00000037
Binary Images Description:
0x1000 - 0x7b0fff mplayer /Library/Application Support/ffmpegX/mplayer
0xd9c000 - 0xef5fff GLEngine /System/Library/Frameworks/OpenGL.framework/Resources/GLEngine.bundle/GLEngine
0xf21000 - 0xf3dfff GLDriver /System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLDriver.bundle/GLDriver
0xf44000 - 0xf68fff GLRendererFloat /System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLRendererFloat.bundle/GLRendererFloat
0x1808000 - 0x1978fff com.apple.GeForceFXGLDriver 1.4.36 (4.3.6) /System/Library/Extensions/GeForceFXGLDriver.bundle/Contents/MacOS/GeForceFXGLDriver
0x14334000 - 0x14384fff com.DivXInc.DivXDecoder 6.0.5 /Library/QuickTime/DivX 6 Decoder.component/Contents/MacOS/DivX 6 Decoder
0x14396000 - 0x143bafff com.apple.iSightAudio 7.1.2 /Library/Audio/Plug-Ins/HAL/iSightAudio.plugin/Contents/MacOS/iSightAudio
0x144d2000 - 0x144d7fff com.apple.audio.AppleHDAHALPlugIn 1.2.4 (1.2.4a19) /System/Library/Extensions/AppleHDA.kext/Contents/PlugIns/AppleHDAHALPlugIn.bundle/Contents/MacOS/AppleHDAHALPlugIn
0x70000000 - 0x700f9fff com.apple.audio.units.Components 1.4.3 /System/Library/Components/CoreAudio.component/Contents/MacOS/CoreAudio
0x8fe00000 - 0x8fe49fff dyld 46.8 /usr/lib/dyld
0x90000000 - 0x9016ffff libSystem.B.dylib /usr/lib/libSystem.B.dylib
0x901bf000 - 0x901c1fff libmathCommon.A.dylib /usr/lib/system/libmathCommon.A.dylib
0x901c3000 - 0x90200fff com.apple.CoreText 1.1.1 (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreText.framework/Versions/A/CoreText
0x90227000 - 0x902fcfff ATS /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS
0x9031c000 - 0x90771fff com.apple.CoreGraphics 1.258.34 (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
0x90808000 - 0x908d0fff com.apple.CoreFoundation 6.4.6 (368.27) /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
0x9090e000 - 0x9090efff com.apple.CoreServices 10.4 (???) /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
0x90910000 - 0x90a03fff libicucore.A.dylib /usr/lib/libicucore.A.dylib
0x90a53000 - 0x90ad2fff libobjc.A.dylib /usr/lib/libobjc.A.dylib
0x90afb000 - 0x90b5ffff libstdc++.6.dylib /usr/lib/libstdc++.6.dylib
0x90bce000 - 0x90bd5fff libgcc_s.1.dylib /usr/lib/libgcc_s.1.dylib
0x90bda000 - 0x90c4dfff com.apple.framework.IOKit 1.4.6 (???) /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
0x90c62000 - 0x90c74fff libauto.dylib /usr/lib/libauto.dylib
0x90c7a000 - 0x90f20fff com.apple.CoreServices.CarbonCore 682.14 /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
0x90f63000 - 0x90fcbfff com.apple.CoreServices.OSServices 4.1 /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices
0x91004000 - 0x91042fff com.apple.CFNetwork 129.16 /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
0x91055000 - 0x91065fff com.apple.WebServices 1.1.3 (1.1.0) /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/WebServicesCore.framework/Versions/A/WebServicesCore
0x91070000 - 0x910effff com.apple.SearchKit 1.0.5 /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit
0x91129000 - 0x91147fff com.apple.Metadata 10.4.4 (121.36) /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata
0x91153000 - 0x91161fff libz.1.dylib /usr/lib/libz.1.dylib
0x91164000 - 0x91303fff com.apple.security 4.4.1 (27569) /System/Library/Frameworks/Security.framework/Versions/A/Security
0x91401000 - 0x91409fff com.apple.DiskArbitration 2.1.1 /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
0x91410000 - 0x91436fff com.apple.SystemConfiguration 1.8.6 /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
0x91448000 - 0x9144ffff libbsm.dylib /usr/lib/libbsm.dylib
0x91453000 - 0x914c9fff com.apple.audio.CoreAudio 3.0.4 /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
0x9151a000 - 0x9151afff com.apple.ApplicationServices 10.4 (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
0x9151c000 - 0x91548fff com.apple.AE 314 (313) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
0x9155b000 - 0x9162ffff com.apple.ColorSync 4.4.6 /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync.framework/Versions/A/ColorSync
0x9166a000 - 0x916ddfff com.apple.print.framework.PrintCore 4.6 (177.13) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore
0x9170b000 - 0x917b4fff com.apple.QD 3.10.20 (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD
0x917da000 - 0x91825fff com.apple.HIServices 1.5.2 (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
0x91844000 - 0x9185afff com.apple.LangAnalysis 1.6.3 /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis
0x91866000 - 0x91881fff com.apple.FindByContent 1.5 /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/FindByContent.framework/Versions/A/FindByContent
0x9188c000 - 0x918c9fff com.apple.LaunchServices 181 /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
0x918dd000 - 0x918e9fff com.apple.speech.synthesis.framework 3.5 /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
0x918f0000 - 0x91928fff com.apple.ImageIO.framework 1.4.8 /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/ImageIO
0x9193a000 - 0x919ecfff libcrypto.0.9.7.dylib /usr/lib/libcrypto.0.9.7.dylib
0x91a32000 - 0x91a48fff libcups.2.dylib /usr/lib/libcups.2.dylib
0x91a4d000 - 0x91a69fff libJPEG.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
0x91a6e000 - 0x91accfff libJP2.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib
0x91ade000 - 0x91ae2fff libGIF.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
0x91ae4000 - 0x91b3ffff libRaw.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libRaw.dylib
0x91b43000 - 0x91b80fff libTIFF.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
0x91b86000 - 0x91ba0fff libPng.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
0x91ba5000 - 0x91ba7fff libRadiance.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
0x91ba9000 - 0x91ba9fff com.apple.Accelerate 1.3 (Accelerate 1.3) /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
0x91bab000 - 0x91c39fff com.apple.vImage 2.5 /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage
0x91c40000 - 0x91c40fff com.apple.Accelerate.vecLib 3.3 (vecLib 3.3) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib
0x91c42000 - 0x91c9bfff libvMisc.dylib /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib
0x91ca4000 - 0x91cc8fff libvDSP.dylib /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib
0x91cd0000 - 0x920fffff libBLAS.dylib /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
0x9214a000 - 0x924fefff libLAPACK.dylib /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib
0x9252b000 - 0x925a8fff com.apple.DesktopServices 1.3.4 /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
0x925e9000 - 0x92819fff com.apple.Foundation 6.4.7 (567.28) /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
0x92925000 - 0x92a03fff libxml2.2.dylib /usr/lib/libxml2.2.dylib
0x92a20000 - 0x92b0dfff libiconv.2.dylib /usr/lib/libiconv.2.dylib
0x92b1d000 - 0x92b34fff libGL.dylib /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
0x92b3f000 - 0x92b97fff libGLU.dylib /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
0x92bab000 - 0x92babfff com.apple.Carbon 10.4 (???) /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
0x92bad000 - 0x92bbdfff com.apple.ImageCapture 3.0.4 /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture
0x92bcc000 - 0x92bd4fff com.apple.speech.recognition.framework 3.6 /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition
0x92bda000 - 0x92be0fff com.apple.securityhi 2.0.1 (24742) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI
0x92be6000 - 0x92c77fff com.apple.ink.framework 101.2.1 (71) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink
0x92c8b000 - 0x92c8ffff com.apple.help 1.0.3 (32.1) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help
0x92c92000 - 0x92cb0fff com.apple.openscripting 1.2.5 (???) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting
0x92cc2000 - 0x92cc8fff com.apple.print.framework.Print 5.2 (192.4) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print
0x92cce000 - 0x92d31fff com.apple.htmlrendering 66.1 (1.1.3) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HTMLRendering.framework/Versions/A/HTMLRendering
0x92d58000 - 0x92d99fff com.apple.NavigationServices 3.4.4 (3.4.3) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/NavigationServices.framework/Versions/A/NavigationServices
0x92dc0000 - 0x92dcefff com.apple.audio.SoundManager 3.9.1 /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CarbonSound.framework/Versions/A/CarbonSound
0x92dd5000 - 0x92ddafff com.apple.CommonPanels 1.2.3 (73) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels
0x92ddf000 - 0x930d3fff com.apple.HIToolbox 1.4.8 (???) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
0x931d9000 - 0x931e5fff com.apple.opengl 1.4.11 /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
0x93275000 - 0x93275fff com.apple.Cocoa 6.4 (???) /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
0x93277000 - 0x9392dfff com.apple.AppKit 6.4.8 (824.42) /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
0x93cae000 - 0x93d27fff com.apple.CoreData 90 /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
0x93d60000 - 0x93e18fff com.apple.audio.toolbox.AudioToolbox 1.4.3 /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
0x93e5a000 - 0x93e5afff com.apple.audio.units.AudioUnit 1.4.2 /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
0x93e5c000 - 0x9402efff com.apple.QuartzCore 1.4.9 /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
0x9407f000 - 0x940c0fff libsqlite3.0.dylib /usr/lib/libsqlite3.0.dylib
0x940c8000 - 0x94102fff libGLImage.dylib /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
0x9428b000 - 0x9429afff libCGATS.A.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCGATS.A.dylib
0x942a1000 - 0x942acfff libCSync.A.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCSync.A.dylib
0x942f9000 - 0x94313fff libRIP.A.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libRIP.A.dylib
0x94319000 - 0x945d3fff com.apple.QuickTime 7.1.2 /System/Library/Frameworks/QuickTime.framework/Versions/A/QuickTime
0x95fcc000 - 0x95ffafff libncurses.5.4.dylib /usr/lib/libncurses.5.4.dylib
0x96a3b000 - 0x96a3bfff com.apple.vecLib 3.3 (vecLib 3.3) /System/Library/Frameworks/vecLib.framework/Versions/A/vecLib
0x96fb5000 - 0x97083fff libGLProgrammability.dylib /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dylib
0x9709e000 - 0x9709ffff libGLSystem.dylib /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLSystem.dylib
0x970a1000 - 0x970a6fff com.apple.agl 2.5.9 (AGL-2.5.9) /System/Library/Frameworks/AGL.framework/Versions/A/AGL
0x98aea000 - 0x99696fff com.apple.QuickTimeComponents.component 7.1.2 /System/Library/QuickTime/QuickTimeComponents.component/Contents/MacOS/QuickTimeComponents
Model: MacPro1,1, BootROM MP11.005C.B00, 4 processors, Dual-Core Intel Xeon, 2.66 GHz, 1 GB
Graphics: NVIDIA GeForce 7300 GT, NVIDIA GeForce 7300 GT, PCIe, 256 MB
Memory Module: DIMM Riser A/DIMM 1, 512 MB, DDR2 FB-DIMM, 667 MHz
Memory Module: DIMM Riser A/DIMM 2, 512 MB, DDR2 FB-DIMM, 667 MHz
Network Service: Built-in Ethernet 1, Ethernet, en0
PCI Card: NVIDIA GeForce 7300 GT, Display, Slot-1
Serial ATA Device: WDC WD2500JS-41SGB0, 232.89 GB
Parallel ATA Device: PIONEER DVD-RW DVR-111D
USB Device: Hub, Up to 480 Mb/sec, 500 mA
USB Device: Hub in Apple Pro Keyboard, Mitsumi Electric, Up to 12 Mb/sec, 500 mA
USB Device: Optical USB Mouse, Logitech, Up to 1.5 Mb/sec, 100 mA
USB Device: Apple Pro Keyboard, Mitsumi Electric, Up to 12 Mb/sec, 250 mA
USB Device: Apple Cinema Display, Up to 1.5 Mb/sec, 500 mA
FireWire Device: iSight, Apple Computer, Inc., Up to 400 Mb/sec
FireWire Device: built-in_hub, unknown_value, Unknown
Results 1 to 1 of 1
Thread: Mac pro Autocrop crashreport
Ripping a Region 2 DVD on a Mac Book Pro with Mac The Ripper
By Jess021 in forum MacReplies: 7Last Post: 17th Nov 2011, 05:04 -
Formate/specs for video file which play smoothly Across G4 MAC/ PC /MAC PRO
By krijes in forum EditingReplies: 1Last Post: 2nd Apr 2010, 05:18 -
Autocrop fails
By w4tt4n4b3 in forum EditingReplies: 0Last Post: 11th Oct 2009, 14:31 -
Force AutoGK to 16:9 after adding pixels to autocrop?
By nerdgeek in forum Video ConversionReplies: 8Last Post: 30th Sep 2007, 12:14 -
ffmpegx autocrop and preview not working anymore
By skankmonky18 in forum ffmpegX general discussionReplies: 6Last Post: 22nd Aug 2007, 01:21
