VideoHelp.com Forum
    I convert iMovie DV's to MPEG-1. Almost always, though, when I play it back in Quicktime it works fine until I skip ahead (fast forward, if you will). Then the frame freezes, the timer keeps going, and I have no audio. Usually, however, it plays just fine in Window Media Player. Occationally, it will have the same problem in that program, too. I desparately need to find out what the problem is.
    Settings are as follows:
    ffmpeg, VCD size, Best video bitrate, 64 audio bitrate, mono, CBR, .mp2.
    Do I need to decode with QT? Any suggestions would be helpful.
    J
  2. Explorer Case's Avatar
    You should test if this is an encoder issue or a player issue. Do your have other MPEG-1 files with the same specs that are encoded by another tool? Do they play/FF better?
    Thanks for the reply. I have checked that. I've made MPEG-1 files with Studio 9 that work perfectly. When I drop the file into ffmpegX it gives me the same specs for both the Studio created file and the ffmpeg engine file. I have the same problem when I play the created MPEG-1 file on my Mac QT Pro and my Windows QT, plus it has problems occationally in WMP. Any other thoughts?
  4. Explorer Case's Avatar
    The ffmpeg engine and the mpeg2enc engine produce different MPEG-1 files. So you might check out how the the other engine's output file behaves.
  5. Originally Posted by garcialove
    J
    That's a constant problem in the ffmpeg mpeg-1 engine. I don't know what's causing this problem though (broken muxer ?). Open your files with MPEG Streamclip, then choose "Convert To MPEG". This should remux the file properly.
  1. Ripbot behaving strangely
    By nikemouse in forum Blu-ray Ripping
    Last Post: 6th Nov 2009, 00:08
  2. I Need New Burner Recommendations Badly
    By Jonathan in forum DVD & Blu-ray Writers
    Last Post: 13th Sep 2008, 16:05
  3. Replies: 27
    Last Post: 6th Jun 2008, 12:11
  4. Replies: 4
    Last Post: 26th Jul 2007, 08:01
  5. How can I rip a badly made DVD?
    By semmel in forum DVD Ripping
    Last Post: 14th Jul 2007, 10:34
