I am having a bit of a problem converting avi's to DVD with the DVD mpeg2enc option. On selecting this option no other changes are made to the settings. The conversion is complete in less than a second with no output file being produced. Below are the type of information logs generated on completion:
example 1
/bin/sh: line 1: /Library/Application Support/ffmpegX/mpeg2enc: Malformed Mach-o file
Encoding started on Wed Aug 16 17:43:49 EST 2006
INFO: [yuvscaler] yuvscaler 1.9.0 (15-02-2004) is a general scaling utility for yuv frames
INFO: [yuvscaler] (C) 2001-2004 Xavier Biquard <xbiquard@free.fr>, yuvscaler -h for help, or man yuvscaler
movtoy4m
Copyright 2002-2006 Johan Lindström
All rights reserved..
++ WARN: [yuvscaler] Could not infer norm (PAL/SECAM or NTSC) from input data (frame size=720x480, frame rate=24000:1001 fps)!!
INFO: [yuvscaler] input: frame size: 720x480 pixels (518400 bytes)
INFO: [yuvscaler] input: chroma: 4:2:0 JPEG/MPEG-1 (interstitial)
INFO: [yuvscaler] input: frame rate: 24000/1001 fps (~23.976024)
INFO: [yuvscaler] input: interlace: none/progressive
INFO: [yuvscaler] input: sample aspect ratio: 1:1
INFO: [yuvscaler] from 720x480, take 720x480+0+0, NOT_INTERLACED/PROGRESSIVE
INFO: [yuvscaler] scale to 720x480, 720x480 being displayed
INFO: [yuvscaler] Scaling uses the RESAMPLE algorithm,
INFO: [yuvscaler] frame rate: 23.976 fps
INFO: [yuvscaler] Scaling ratio for width is 1 to 1
INFO: [yuvscaler] and is 1 to 1 for height
INFO: [yuvscaler] Specific downscaling routing number 4
example 2
Wed Aug 16 17:51:13 EST 2006
movtoy4m
INFO: [yuvscaler] input: frame size: 720x304 pixels (328320 bytes)
INFO: [yuvscaler] input: frame rate: 30000/1001 fps (~29.970030)
INFO: [yuvscaler] from 720x304, take 720x304+0+0, NOT_INTERLACED/PROGRESSIVE
INFO: [yuvscaler] scale to 720x304, 720x304 being displayed
INFO: [yuvscaler] frame rate: 29.970 fps
Converting these files with DVD ffmpeg option proceeds with no problems. Could anybody shed some light on what may be going on here? I am using the latest release of ffmpegx on an intel machine with 10.4.7.
Thread: avi to DVD mpeg2enc problem
It seems the installation of mpeg2enc didn't go well: 'Malformed'Originally Posted by chubby1
Try to install a fresh copy of mpeg2enc using the Install Binaries option in the ffmpegX menu.
MPEG2ENC dowload problem
By blue439 in forum MacReplies: 7Last Post: 6th Nov 2011, 00:46 -
Avi to DVD (mpeg2enc), doesn't fit screen (noob)
By bilboshaggins in forum ffmpegX general discussionReplies: 7Last Post: 14th Dec 2008, 14:53 -
Crash in 0.0.9y converting AVI to DVD using mpeg2enc profile
By mainframer in forum ffmpegX bugs and suggestionsReplies: 0Last Post: 20th May 2008, 01:05 -
Problem with mpeg2enc binary
By lkearl in forum ffmpegX general discussionReplies: 1Last Post: 11th Aug 2007, 03:47 -
Problems w/selectable subs avi-DVD w/mpeg2enc
By kenzo69 in forum ffmpegX general discussionReplies: 1Last Post: 20th May 2007, 05:53
Statistics
Newest guides
Latest tool updates
New media comments
