PURPOSE:
This software is designed to convert audio files between different formats.
This is the first real beta release… so at this point you can only convert MP3 to AMR, MP3 to AC3 and you can resample MP3 files. You can select a segment of the file and encode it (just because someone asked me that to make mobile phone ringings :0)
All the tools needed to make it work are included on the installation pack and they are (at this point) ffmpeg.exe, mediainfo.dll and AviSynth 2.5.6 that will be Installed if not detected on your system.
Please, inform me about any problems and/or bugs you may find.
26th March 2007 - v.0.1.9 beta
here: http://forum.videohelp.com/viewtopic...3cfdec#1679827
12th March 2007 - v.0.1.8 beta
here: http://forum.videohelp.com/viewtopic...672207#1672207
10th March 2007 - v.0.1.7 beta
here: http://forum.videohelp.com/viewtopic...671175#1671175
5th December 2006 - v.0.1.6 beta
here: http://forum.videohelp.com/viewtopic...619339#1619339
4th December 2006 - v.0.1.5 beta
here: http://forum.videohelp.com/viewtopic...618384#1618384
13th August 2006 - v.0.1.2 beta
* Enabled MP3 to MP3 encoding.
* Enabled MP3 to AC3 encoding.
* Enabled AMR Wide-Band Encoding.
* Enabled the selection of one "segment" for cuts... this feature requires AviSynth installed on your system...
* Restructured the Interface... for better... I hope)
* Added the option to export de encoded file to the same folder of the original file just leave the option "Same Output Folder" checked.
* Fully translated to English.
A very special thank you goes to my wife, my son and to my daughter... they
are the "main victims" of the time I spent developing this tool
Thanks to:
* Desassossego for the all beta testing.
* Another special thanks goes to Xena for all the testing, patience
and tips along the way (past, present and future lol).
* All the AviSynth development team.
* To Fabrice Bellard the creator of FFMPEG
* To all the FFMPEG development team and all that contributed for its
evolution and improvement.
* To Jordan Russel, the creator of InnoSetup.
* To Zenitram creator of MediaInfo
NOTE: THIS IS A BETA SOFTWARE… THAT MEANS IT MAY HAVE SEVERAL BUGS AND GLITCHES… IF YOU USE IT YOU ARE AGREEING THAT YOU ARE WILLING TO LOOSE YOUR PATIENCE AND INSULT THE DEVELOPER… JUST DON’T TELL HIM ABOUT IT :0)
Instalation Pack (Suggested) - 4.46MB
Content:
* DAudioK Executable.
* Documentation (readme.txt and LGPL.txt).
* COMDLG32.OCX
* MediaInfo.dll.
* FFMPEG (executable, AVSredirect.dll and pthreadGC2.dll).
* AviSynth (The installer will check if it exists on your system... if not will instal v.2.5.6... it is required for some DAudioK features).
RAR Pack - 3.20MB
Content:
* COMDLG32.OCX
* MediaInfo.dll.
AviSynth not Included - Use this RAR file only if you know what it AviSynth and if you have it installed on your system.
Downloads at: www.rockassoftware.pt.vu
Results 1 to 30 of 50
Thread: DAudioK v0.1.9beta
My oppinions may change, but not the fact that I am right!
DAudioK => http://forum.videohelp.com/viewtopic.php?t=306886
DVD Rebuilder
http://dvd-rb.dvd2go.org
http://www.jdobbs.com
25th September 2006 - v.0.1.3 beta
* * Added "Portuguese" language. You can set your prefered language on the
Setup dialog (Menu "Tools" -> "Setup")
* * Added the possibility to choose the path to ffmpeg executable on the
Setup dialog -- this will give the possibility to use different versions.
NOTE: This software has been tested with the ffmpeg.exe included on the
Installer or the RAR package... if you're going to try a different version
I can't garantee that it will work.
* * Now, all the option selected will be saved. Next time you start the
application, the options will be set to your last selections (I hope :0))
* * Added a "Tags Display" feature. The data will be used to pass the tags to
the newly encoded file... on the previous releases the Tags were lost. You
can change the tags of your target file if you change the data before
encoding. The tags will be saved using the ID3 v 1.0, 1.1, 2.2, 2.3 and 2.4.
(ID3 tagging module by Mathias Kunter (www.magic-tagger.com))
* * Some minor bug corrections.
* * Some minor cosmetic changesMy oppinions may change, but not the fact that I am right!
DVD Rebuilder
2nd October 2006 - v.0.1.4 beta
- * At this point you can convert between MP3, AC3, MP2 formats, you can convert WMA to MP3, WAV to MP3, MP2 and AC3, MP3 to AMR and you can resample MP3, AC3 and MP2 files.
* Updated the Installer so now it has an "Update Only" option -- you can select the "update" option on the top of the "components selection" dialog.
* I removed the "'X' to 'Y'" modes -- what was I thinking?!?!. Now you just have to choose the output format... this is really beta, but it seems to be working fine. I haven't tested it on a completly "clean" system, 'cause I don't have one :0)
* Made a few corrections on the MP3 Tag module. The "Genre" was being tagged wrong and there was a conflict between versions that could make some software not recognize the tags correctly.
* Added a routine to correct the extension if you change the output format after setting the "output file" -- the extension will be changed according to the new output format.
* Added a "File Exists" warning that shall popup everytime the Output file name already exists.
* Added a "check for new versions" feature -- you can access its definitions on the Setup dialog -- this feature only accesses a remote file to get the latest version number... no data from the local system is collected or sent.
* Fixed a Bug on the AMR Bitrate combo introduced on version 0.1.3 beta
* Some cosmetic changes.
DVD Rebuilder
First of all, I'm sorry for such a delay on a new release... my day job got pretty complicated on the last couple of months so my free time was really short... anyway... I think I'll manage to keep the updates on a regular bases at this point.
Thank you for all the support.
As always... feedback is more than welcome.
- *Added WAV and AAC output formats.
*Added an "Abort" encode button... as it says... aborts the encoding process.
*Changed the default MP2/MPA bitrate to 224kbps... sorry about this one, I simply didn't noticed (Copy/Paste mistakes :0$). This is no big deal unless the user is a beginner and wants to make audio for VCD, SVCD or DVD... in that case, 224kbps is "suitable" for all.
*Corrections on the translation routine -- some items didn't got translated.
*To avoid unauthorized translations of the interface, I've introduced a routine that will re-write the language file everytime this application is started. If you want to translate the program to your mother language, please contact me through daudiok@gmail.com or rockassoftware@gmail.com, I'll be extremely glad to accept your contribution and you'll get the credits for your work printed on the Software Interface.
*Added a "Vista" option under Setup dialog. That option can be used to adapt the main window size to the new "Vista looks".
*Some minor bug corrections.
*Some minor cosmetic changes.
*Updated Translation routine for the new features.
DVD Rebuilder
- Introduced the "Spanish" language...
Thank you KarlMTC
- Introduced the "French" language...
Thank you Desassossego
- Introduced the "German" language...
- Corrected an error introduced on v.0.1.5 beta. Some cosmetic changes caused
a malfunction on some systems... sorry about this one :0(My oppinions may change, but not the fact that I am right!
DVD Rebuilder
hey Rockas!
you are Rock!!
this is the only tool i founded, that can encode a 6 channel ac3 Audio Stream.
i tried at least 5 tools ,including the ac3 codec with virtualdubmod but without success.
keep the good JOB!
since it is a beta it will nice to add a time remainig status when encoding ,and a possibility to manualy
choose the bitrate(by typing it).
and in the future.....maybe rip the sound from it's source(avi,vob,etc...).
don't stop man! this tool it's brilliant!
oh that's good, real good. will the "batch" button be active
soon? same for fade in/out and normalize? gettin' greedy now! this is a tool for my bag for sure..thanks!
Thanks for the kind words guys
The Batch button will have to wait a little more time... same for the Fade in/out.
Normalize will be available on the next release.
I'm adding the possibility to UpMix from stereo to 5.1.
Some bug fixes as usual.
It will be out soon - depending, as usual, of my Day Job
DVD Rebuilder
From now on, all the Audio will be frameserved through AviSynth that means that the presence of AviSynth on your system is a obligatory - this is not applied when the output format is WMA, this means that no "Normalize" or segments cut can be applied at this moment.
Updated the AviSynth version included on the Installer -- you may want want to uninstall the previous version... the installer will detect that AviSynt is not present on your system and will install a reduced version of AviSynth 2.5.7 -- if you want the full version you can get it at www.avisynth.org.
Updated FFMEG to a newer release compiled by Celtic Druid.
Added a Stereo To 5.1 UpMix feature -- at this point its only possible to make 6channels AC3 files -- A huge thank you to Rockaria and dimzon (doom9.org) for the base AVS(AviSynth) script provided through BeHappy.
*http://forum.doom9.org/showthread.php?t=104686.
*http://workspaces.gotdotnet.com/behappy
note: to use this feature you'll need SoxFilter (by Klaus Post) on your AviSynth plugins folder -- if you use the DAudioK Installer this filter will be installed under "tools/plugins" on DAudioK installation folder.
Changed the AC3 encodings from FFMPEG to QuEnc -- QuEnc is included on the self installer package and on the RAR Package -- you can point the path to QuEnc on the Setup dialog.
Added the WMA output format -- only the default WMA profiles will be available at this point... more advanced options will be added on next releases.
Added AVS and DTS as Input formats -- you can use AVS to encode your own custom scripts.
Added Real Audio audio files as Input Format (.ra and .rmj) - you may need to install Real Alternative so you can have the necessary DirectShow filters.
Updated MediaInfo to the latest version -- from now on the data (tags) from the audio files will be collected using the CLI of the latest version. It will be installed under DAudioK installations folder inside "Tools/MediaInfo".
Added a "normalize" option -- the 'normalization" will be performed through AviSynth.
Corrected a bug on the mp3 "channels set" routine.
Corrected the encoding volume -- the volume values were not working at all. I also changed the max volume to 100 -- the ffmpeg version in use doesn't increase the output files' volume.
Resized some interface components. Some words of the new languages weren't fitting on the space available.
Introduced an experimental "LOG" routine -- this will be pretty incomplete for the time being... I'm hoping to add some more usefull info on the next releases -- to visualize the Log you must activate its window under "File" menu.
The progress bar will be displaying the correct progress of the encoding process -- a huge thank you to jdobbs on this one.
Note: To use wma encoding feature you may need to download WME 9 Series
Windows Media Encoder 9 Series
Home Page:
http://www.microsoft.com/windows/win...r/default.mspx
32bits 9.5MB
http://www.microsoft.com/downloads/d...displaylang=en
64bits 12.4MB
http://www.microsoft.com/downloads/d...displaylang=enMy oppinions may change, but not the fact that I am right!
DVD Rebuilder
- Fixed the UpMix feature -- one last minute change made this function not work at all... yes I banged my head against the wall times enough now.
- Updated the Mediainfo version to the latest.My oppinions may change, but not the fact that I am right!
DVD Rebuilder
0.1.7 beta release....
i have switched to this last beta from the prev one,and was
disappoint.i have a movie with 2channels ac3 sound
and wanted to convert it to 6 channel 48000 without success.
when input was a demuxed sound file ac3(with virtualddubmod) app crash!
(ac3 2 channels --> ac3 6 channels)
when input was a pcm Wav file result was a 2 channel file, when choosed 6 channel 48000 for output(the 48000 was done)
when input was a saved Wav file result was a 2 channel file, when choosed 6 channel 48000 for output(the 48000 was done)
all the tests where made with the "Match Point" movie sample.
source input was ,ac3 2 channel file with a 192 bitrate.
** with prev beta ,i was able to get a 6 channel ac3, but not
encoded well has i wanted(conversation on center)
on develop, one of the most important issues, it's patient....
it's happen to everyone rockas....
buy the way...how can i translate it to my region language? there is a xml file anywhere?
thx in advanced, and keep doing a good job.
Thanks for your feedback.
Have you tried version 0.1.8beta?
Please let me know if that fixed the issue.
Yes you can translate the application... I would be great!
Please send me your e-mail address through PM, ok?
thank you.My oppinions may change, but not the fact that I am right!
DVD Rebuilder
Thank you... I'll check out what's happening.
DVD Rebuilder
tested the v0.1.8beta with the same sample file that i used before.
now ,pcm wav file, wich was decompressed via virtualdubmod, works fine.
(included the down mix option)
i also tried to reencode the same, but didn't choosed pcm, i choosed "save wav" when
"direct stream" option was selected in virtualdubmod ,and the result was a silent file....
i was wondering if it's possible to get a really AC3 6channel audio file, when input it's ac3 2 channel...
when i added the successful encode to my avi file and tested it on my stand alone DVD player,
the result wasn't as an original 6 channel audio.
in a real one, conversation for example has to eared on center.
(maybe it's impossible to "fix" the source...
hmmm... it has to do with the channel mapping.
i'll have to come up with a method of letting people change it...
the non centered "conversation" only happened with the AC3 source or it happened with the WAV too?My oppinions may change, but not the fact that I am right!
DVD Rebuilder
well....the ac3 2 channels(demuxed) to 6channels don't work in this version, so i couldn't test it.Originally Posted by Rockas
when ac3 to ac3 is selected(source it's an ac3 demuxed audio file) the app Crash!.
i could only test wav to ac3.as i told before,i have decompressed the ac3 to a pcm wav file
and reencode it.
hmmm... this is very odd... I tested some AC3 2CH and it worked fine.
Can you send me a sample to daudiok@gmail.com? a small sample, ok?
Thank you
DVD Rebuilder
- Fixed a bug on the Installer -- using the custom instalation option, the
main application files would not get installer -- Thank you to gsing for
pointing this out
- Fixed a bug related to an accidental FFMPEG executable launching -- this
could result in an encoding failure.
- updated Microsofts' "WMCmd.vbs" for the latest version, now it's possible
to use AVS scripts to fees the WM encoder so... the "normalization feature
is enabled -- my thanks to Zambelli
- corrected the "save as" procedure -- when output format was set to WMA it
wasn't working.
- added DTS files as source files -- a directshow filter will be installed
(dtssource.ax) to enable this function.
- Corrected the installer so WMA files can be encoded.My oppinions may change, but not the fact that I am right!
DVD Rebuilder
Any news on the problem converting DTS to AC3 whereby the centre channel (speech) ends up coming out of the right speaker? Would be great if this issue could be sorted out
Andy
I'm finishing a new version that I expect to release soon.
It won't bring nothing really new on that issue but after that I will start working on that.
This new release is taking so long 'cause my "day job" got a bit complicated lately and because I'm introducing some "Advanced Tags" feature.
in the mean time... can you tell me what is the DTS Direct Show filter that you are using?My oppinions may change, but not the fact that I am right!
DVD Rebuilder
errrmm, I think I'm using AC3Filter, to be honest I'm not sure, how would I find out for definite?
the easier way is to play the file on the old "windows media player".
you can find it on Windows Media Player folder and the exe is usually "mplayer2.exe".
Just put it to play the file then right-click and select "properties". The used filters are shown on the "advanced" tab.My oppinions may change, but not the fact that I am right!
DVD Rebuilder
It's using AC3Filter
Ok... thank you for the info.
DVD Rebuilder
Hi,
This tools likes like it'll be great when its finished.
I downloaded the tool to convert WMA to WMA (i.e. to downsample tracks and maintain the tags), and hopefully to be able to do this in batch mode. However - when choosing a WMA file (192Kbs - CBR) and selecting to convert to a new file (but at 128Kbs) in same folder (see screen shot) - I get a run time error.
Any tips would be useful. In the mean time - if anyone knows of a tool (open sourec pref) that can do this - I'd like to know (please dont advise "Switch" - as it does the conversions just fine - but does *not* transfer the tags
Screen shot attached. Anything I can do to help - just let me know.
Q.
That is a wierd one.
Can you please send me one of the files where you get that error at daudiok@gmail.com?
Thank youMy oppinions may change, but not the fact that I am right!
DVD Rebuilder
Hi,
File sent to your email account.
HTH
Q.
Thank you. I will take a look and then contact you,
Cheers,
RockasMy oppinions may change, but not the fact that I am right!
DVD Rebuilder
I have also found that when I convert from dts to ac3 and even from ac3 to ac3 I get it where all the front channels come out of the right speaker and all the rear channels come from the left speaker. This happens when converting to 2 channel or keeping the 5.1, it's a shame because this is the highest quality converter I have found. I was using besweet, but it caused the audio to go to a much lower quality and the volume to sort of strobe up and down.
Keep up the good work!
Runtime Error '6'Overflow on DAudioK
By FatalX in forum AudioReplies: 0Last Post: 15th Oct 2010, 09:27 -
DAudioK gives me an error messeage
By Belfour in forum AudioReplies: 0Last Post: 4th Jan 2009, 14:50 -
DaudioK software error
By volam in forum AudioReplies: 3Last Post: 6th May 2008, 10:13 -
Need Help converting DTS to AC3 5.1 Using DAudioK or Similar?
By neo_74 in forum AudioReplies: 1Last Post: 1st Jan 2008, 15:53
