VideoHelp.com Forum
  1. hi,
    im using osx 10.3.9 with imovies and idvd from `06. i made a dvd from som dv footage and then deleted the original footage plus the mpeg - so all i have now is the dvd (video_ts file)
    now i want to make a compilation of several clips into a new dvd and want to access only one scene from the dvd i made and include it in the new compilation dvd.
    my question is how do i extract the dvd footage back into imovies so that i can edit it. i tried to convert the dvd into an avi with ffmpex 0.0.9s - however it wont allow it saying it is illegal!
    can anyone suggest another way?
    thanks
  2. Explorer Case's Avatar
    Afaik, ffmpegX won't take input directly from the disc, copy/rip it to your hard disk drive first.
    2nd, iMovie works in DV format, so going to AVI first will result in 2 conversions; more than needed.
    Alternatively, MPEG Streamclip (+QuickTime MPEG-2 Playback Component) can transcode MPEG-2 from DVD to DV.
    I'm sure some other users have other favorite tools for this.
    MPEG Streamclip or Cinematize 2 are your best bets for selecting a scene from a video DVD and extracting that as a .mov file for use in iMovie. You can do the extraction straight from the disc since it is not copy protected.
  4. thanks, will give it a shot!
  1. Converting from .Mod and creating iMovies
    By jfbrackin in forum Mac
    Last Post: 24th Dec 2009, 11:38
