VideoHelp.com Forum
    How to convert avi/divx PAL files into DVD-NTSC?
    Do you know any software to do that? Thanks a lot!
  2. Member teegee420's Avatar
    Check out the "CONVERT" section on the left. There are several options.
  3. Mod Neophyte Super Moderator redwudz's Avatar
    You might try ConvertXToDVD. It handles PAL to NTSC fairly well for a all-in-one.
  1. can you convert pal files to ntsc?
    By videodude1966 in forum Newbie / General discussions
    Last Post: 28th Jan 2010, 00:32
  2. Cant convert Pal .AVI to NTSC DVD in Avidemux
    By Hittz in forum Video Conversion
    Last Post: 5th Nov 2009, 07:43
  3. ffmpeg won't convert files from Pal to NTSC, mpegstreamclip does
    By ruggerjvd in forum ffmpegX general discussion
    Last Post: 8th Jun 2009, 08:39
  4. Can AutoGK convert PAL Region 3 dvd to NTSC .avi?
    By bloomcounty in forum Video Conversion
    Last Post: 20th Nov 2008, 19:31
  5. Best point at which to Convert?? (NTSC AVI to PAL DVD)
    By junk in forum Video Conversion
    Last Post: 28th Jun 2007, 16:15
