Sorry if this is a repost, but I really didn't know what to search for. My problem is that my laptop does not have a firewire port, but I want to transfer my video on my mini camcorder to my hard drive. I had no idea that this would be such a hassle, I thought USB was compatible with practically everything under the sun. Any suggestions?
What do you do with a BA in english?
sorry, seem to have found a thread relating to this problem. I'll check it out.
Camcorders really only output full DV quality images via the Firewire port (as data stream), so you really need a firewire adapter.
Has nothing to do with "compatibility".
Look for a PCMCIA card that has firewire (or a FW/USB2 combo card). There are a number of choices and it's not that expensive (?? ~$50 US ??).
Any other way and you're greatly compromising the quality.
You didn't say you cared about video quality.
Sure you can transfer video over USB at CIF 352x240/288 or less. Worth about as much as a BA in english
http://www.kiva.org/about
Actually there is one expensive cable that you could use to this task. This cable will send DV over USB2 through non standard adapter and a proprietary application. It will work, but it is not recommended. http://www.usbfirewire.com/Parts/rr-527950.html
Getting a firewire pcmcia card will give the best results at the best price.
transferring a file to external hard drive not working
By angryassdrummer in forum ComputerReplies: 5Last Post: 15th Apr 2011, 22:27 -
Transferring AVI to Sony Hard Drive recorder - Advice please
By porty in forum Video ConversionReplies: 13Last Post: 20th Dec 2009, 03:33 -
Transferring files from hard drive to Zune
By maroonx in forum Portable VideoReplies: 1Last Post: 25th Jul 2008, 22:30 -
Pioneer DVR-550H-s: transferring video from laptop to DVR's Hard drive
By anandmahey in forum DVD & Blu-ray RecordersReplies: 2Last Post: 10th Feb 2008, 08:13 -
Transferring video to hard drive.
By vid83 in forum Newbie / General discussionsReplies: 16Last Post: 11th Dec 2007, 21:41
