VideoHelp.com Forum
Results 1 to 12 of 12
    i dont know why but it just says its finished in a second and never converts it. Can anyone tell me if im doing anthing wrong or if i need to updates anything?- just some advice would be great , thx.
  2. Explorer Case's Avatar
    After the (failed) conversion is done, press the button in the ffmpegX Progress window, to get the log. Copy that to a text file and attach to a post here, so we can have a look. The log should hold information on what it failed on, then hopefully we can suggest a why and a fix.
    here,
    FFmpeg version CVS, Copyright (c) 2000-2004 Fabrice Bellard
    Mac OSX universal build for ffmpegX
    libavutil version: 49.0.0
    libavcodec version: 51.9.0
    libavformat version: 50.4.0
    Seems that stream 1 comes from film source: 1000.00 (1000/1) -> 29.97 (30000/1001)
    Thu Aug 10 23:28:06 EDT 2006
    from '/Users/Jake/Desktop/killzone_081005_wmvlowwide.wmv':
    Duration: 00:02:04.7, start: 3.000000, bitrate: 1303 kb/s
    Stream #0.0: Audio: wmav2, 48000 Hz, stereo, 128 kb/s
    Stream #0.1, 29.97 fps(r): Video: WMV3 / 0x33564D57, 320x180
    Codec type mismatch for mapping #0.0 -> #0.0
  4. Explorer Case's Avatar
    It seems your clip has the order of video and audio reversed. The audio stream is listed before the video stream; and ffmpegX expects it the other way around. There is a checkbox in the audio tab to "invert mapping", which tells ffmpegX how to deal with that. Tick that checkbox and encode again.
    You are trying to trancode wmv into something else, I suppose. (MPEG-4 Part 2?) I won't say ffmpegX is never capable of handling WMV. However, when it comes to WMV3, chances that ffmpegX can handle it are low. That's my personal experience with ffmpegX v.0.99u. So I don't know if the latest version gives you better luck.
    didnt work , i got this now-
    Encoding started on Fri Aug 11 13:55:39 EDT 2006
    Input #0, asf, from '/Users/Jake/Desktop/killzone_081005_wmvlowwide.wmv':
    Output #0, mp4, to '/Users/Jake/Desktop/M4V05495.MP4':
    Stream #0.0, 29.97 fps(c): Video: xvid, 320x240, q=3-9, 450 kb/s
    Stream #0.1: Audio: aac, 24000 Hz, stereo, 128 kb/s
    Stream mapping:
    Stream #0.1 -> #0.0 [sync #0.0]
    Stream #0.0 -> #0.1 [sync #0.1]
    Unsupported codec (id=74) for input stream #0.1
  7. Explorer Case's Avatar
    Like tbluewater said, some WMVs are unsupported. I suppose the Play button won't work then, either?
    do u think it'l be supported in the future?
  9. Explorer Case's Avatar
    That's one for the developer, I suppose.
    No clue.
    There are two ways to handle WMV. If you have Virtual PC, you can transcode WMV3 into XviD or whatever without spending a dime. Another way of doing it is use of shareware. One Mac shareware that I know does it, too.
    what's it called?
    I am currently having the same problem with the same log info, has there been any updates to this issue that might help me out?
  1. Replies: 102
    Last Post: 2nd Apr 2012, 10:35
  2. Replies: 78
    Last Post: 24th Feb 2011, 09:53
  3. Codec problems with mov, mp4 and wmv
    By lyrd in forum Linux
    Last Post: 29th Jul 2008, 14:30
  4. ffmpegX not working for PSP video
    By thuriel in forum ffmpegX general discussion
    Last Post: 20th May 2007, 08:50
