Hello:
I have a dvd with subtitles out of sync,
wich app can I use to fix it?TIA
Fiona from Argentina
Thread: Rebuilding a dvd help
With a DVD it may get a little more complicated, but for general subtitle work, here's a few:
DVDSubEdit
Time Adjuster
VisualSubSync
Subtitle Workshop
And this link to our subtitle tools: http://www.videohelp.com/tools?s=24#24
And since you are asking specifically about subtitles, I'll move your post to our Subtitle Forum, where you may get better answers.
Assuming they're out of synch by the same amount all the way through, and moving them forward or backward in time by the same amount will fix them, then DVDSubEdit is the tool for the job, as it can fix them within the vobs (i. e., without demuxing):
http://www.videohelp.com/~DVDSubEdit...l/helpfile.htm
It's in Section 3.2
Rebuilding a 3D Bluray?
By micflair in forum Blu-ray RippingReplies: 4Last Post: 5th Jul 2010, 16:44 -
Force subs without rebuilding?
By tbone8 in forum Authoring (Blu-ray)Replies: 3Last Post: 28th Apr 2010, 16:12 -
No dts-hd after bd rebuilding
By Gizzie666 in forum Blu-ray RippingReplies: 2Last Post: 10th Apr 2010, 08:45 -
Recording TV -> burning DVD -> storing on PC -> rebuilding DVD
By ipolicky in forum DVD RippingReplies: 2Last Post: 27th Oct 2009, 04:16 -
Rebuilding my PC again (8th build) and a good reason for rebuilt pc
By MidnightMike in forum ComputerReplies: 11Last Post: 23rd Nov 2008, 01:39
Statistics
Newest guides
Latest tool updates
New media comments
