which one is better for quality? hd or hdv?
Thread: hd hdv
123456
Perhaps you could rephrase this question with some detail and context ?
I wanted to ask which camcarder is better?
hd camcorders or hdv camcorders (for quality)123456
well true hd camcorders can cost over a 100,000$ like the Sony HD F900 and are considered pretty good ....
HDV is a lot cheaper and a LOT lower bit rate and really only 1440 res. with a lot cheaper lens, but it is still good for some applications .....
Perhaps you could rephrase this question with some detail and context as to what you are comparing .. as it is a just a guess right now .."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650)
like use a model number of the ones you mean ..
Apparently HD is better.
Go here for a comparison.
Jim
"HD" isn't a recording format specification unless you mean totally uncompressed to disk. Even then you have 720p, 1080i, 1080p with 8bit, 10bit or log14bit at various frame rates.
Do you mean IMX-HD, DVCPro-HD, HDCAM, HDCAM-SR?
HV40: Record in HDV(PF24) vs HDV(24F)
By videobread in forum Camcorders (DV/HDV/AVCHD)Replies: 12Last Post: 23rd Dec 2011, 20:44 -
From HDV shooting to HDV watching
By MI6 in forum Camcorders (DV/HDV/AVCHD)Replies: 2Last Post: 26th Apr 2008, 13:05 -
is HDV right for me?
By ShBm in forum Camcorders (DV/HDV/AVCHD)Replies: 4Last Post: 14th Apr 2008, 03:02 -
HDV to DV (4:3)
By PeterK in forum Camcorders (DV/HDV/AVCHD)Replies: 3Last Post: 17th Jul 2007, 11:21 -
From DV to HDV
By seven_deuce offsuit in forum Camcorders (DV/HDV/AVCHD)Replies: 5Last Post: 4th Jul 2007, 19:15
