The 4th of Nov. 04 I bought a Samsung DVD P142 (zone 2 Italy), applied the hack as shown on many sites, press repeat, then 5,7,5,3,8 and then number 02 appeared, changed it to 9 etc. It worked beautifully and watched many films. Bought new TV changed hook-up to rbg connections, today went to play a US film, all lights flashing disc is wrong code. Changed connection to TV back to the way it was but DVD will no longer accept hack code. First time you try all numbers showed on screen, 57538, but number 02 did not appear. On repeated tries you can enter 57 but then they disappear before you can enter the rest of the numbers???? Tried unplugging etc, can't find anything that works, any ideas out there? Thanks.
Thread: Samsung hack NO LONGER WORKS????
Does the player read any discs at all now?
Google is your Friend
Yes it does, it seems to have reverted back to a zone 2 machine like it was when I bought it, only now it will no longer accept the hacker code.
You've tried about everything I would suggest. The most common fix is to unplug and leave powered off for an extended period of time.
?? Radio Stream No Longer Works ??
By JaxGuy in forum Video StreamingReplies: 1Last Post: 23rd Nov 2011, 18:34 -
AC3 no longer works w/ WMP 11
By dmjerbear in forum AudioReplies: 2Last Post: 5th May 2009, 22:14 -
DVD burning nightmares...it no longer works???
By apollo1980 in forum Authoring (DVD)Replies: 1Last Post: 27th Dec 2008, 16:22 -
samsung drive no longer available
By newtie in forum DVD & Blu-ray RecordersReplies: 4Last Post: 17th May 2008, 12:42 -
All in Wonder TV Tuner no longer works
By BeerSnob in forum Newbie / General discussionsReplies: 29Last Post: 23rd Mar 2008, 02:52
Statistics
Newest guides
Latest tool updates
New media comments
