VideoHelp.com Forum
  1. Member dawsonj's Avatar
    Is there a utility of set of utilities that will let me
    a) capture 1080i raw or nearly raw from camcorder to PC (SONY HDR-HC3) via firewire cable
    b) select frame by frame until I have frame I want
    c) capture frame as jpg or bmp in highest resolution possible?
    Don't want to spend half of the camcorder cost just buying software to do this. Is there a set of free tools or low cost tools that would work?
  2. Member steveryan's Avatar
    He's a liar and a murderer, and I say that with all due respect.
  4. Member dawsonj's Avatar
    thanks to you both.
    I now have captured MPG2 and used virtual dub to save as avi.
    Now wondering how I can extract one frame from either of these videos and save as mpeg or bitmap in highest possible resolution???
    THanks again for help
  5. Член BJ_M's Avatar
    use virtualdubMOD or some program like VEGAS
    dont convert first to avi if you want best quality (unless lossless format)
    ussually you would capture HD DV with cineform and use that file --
  6. Member dawsonj's Avatar
    Thanks so much. I used the menu video...
    ON the vide menu I found "snapshot source frame".
    This let me save as bmp and I am very happy it works.
    Is there any difference between snapshot source or output frame?
    Is there any difference between snapshot or copy to clipboard?
    Noth questions couched in terms of output quality.
  1. Can't capture from HDV tape!
    By frlane in forum Media
    Last Post: 2nd Jul 2009, 15:43
  2. Watching HDV footage - 1080i CRT vs. 720p LCD
    By JohnnyMalaria in forum DVB / HDTV
    Last Post: 21st Feb 2008, 01:29
  3. Mpeg-2 HDV 1080i to Final Cut
    By The Sumerian in forum Video Conversion
    Last Post: 12th Dec 2007, 22:07
  4. HDR-HC1E 1080i HDV -> MP4 PS3???
    By tobyed2 in forum Camcorders (DV/HDV/AVCHD)
    Last Post: 2nd Nov 2007, 11:37
  5. Is it doable to convert HDV/.m2t 1080i files to AVI files and what...
    By Canon GL-2 Guy in forum Newbie / General discussions
    Last Post: 30th Sep 2007, 04:03
