I have a 10 bit blackmagic MOV file here, on a PC HDD, that was copied across from a MAC drive.
These can be freely copied, but the person whoi copied it has cocked it up & I cannot open it at all.
QT Pro tells me it's not a valid video file, and no conversion/encoder tool will open it at all.
How can I recover this - this is seriously urgent.
www.opusproductions.com
www.opusproductions.co.uk
Digital Audio Specialists
Who wants to be an expert when an ex is a has-been and a spurt is a drip under pressure?
If it is corrupted then there may be little you can do unless you can get in a reconstruct the corrupted parts using a hex editor. Your best bet is to go back to the source and get a new copy.
That is the conclusion we had (reluctantly) come to.
The Mac has completely corrupted the copy somehow.www.opusproductions.com
not to start a new topic, I'll post my problem here.
I had .mov clips on my hard drive, plugged the drive into Mac. At first everything was ok, but then at some random point some of .mov files just stopped playbacking. They do not open in quicktime, Final Cut or VLC. Didn't change anything, even info of both corrupted and "good" clips is the same. I googled some file repairing software, came across one called "Treasured" and it actually started to repair the file (I could see the image) but it asked to download teh full version and pay some crazy amounts of money to repair it.. I would probably even do that, 'cause the clips are important, but I read reviews and, well, people do not recommend to use that software.
Any ideas what might have happened and what could be done ?
Thank you.
Nikon Coolpix corrupted .mov video file repair
By darrenpj in forum Video ConversionReplies: 3Last Post: 31st Mar 2012, 17:15 -
Corrupted/damaged video file .avi
By aizen in forum RestorationReplies: 8Last Post: 31st Jan 2012, 13:17 -
I have a corrupted Quicktime MOV file I need to fix.
By Videogamer555 in forum RestorationReplies: 0Last Post: 5th Mar 2011, 00:51 -
Corrupted MOV file shows up as MPG
By jblc in forum Video ConversionReplies: 0Last Post: 10th Jan 2010, 14:15 -
Hexediting corrupted .mov file, please!
By darkie1213 in forum RestorationReplies: 2Last Post: 17th Nov 2009, 08:46
Statistics
Newest guides
Latest tool updates
New media comments
